Main : Members : 1200rallycar adj strut1
[<   Previous  76  77  78  79  80  81  82  Next   >]
adj strut1
adj strut1Popular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2003/4/26 14:39    Tell a friendTell a friend
Hits3366  Comments5    0.00 (0 votes)0.00 (0 votes)
pics which were emailed to me
if you are the person that emailed me please contact me again cause i lost your email
AlcoholicA
Posted: 2003/5/4 11:36  Updated: 2003/5/4 11:36
 Re: adj strut1
*sniff sniff* i smeel 3d Studio max...shudder...much better in unigraphics or solid edge...he once i get my multimedia/engineering comp up and running i'll make a dat 1200 in full 3d down to the last detail...with some mods...might b a while thou...does cost and a take a lot of time
converted
Posted: 2003/5/4 11:55  Updated: 2003/5/4 11:55
 Re: adj strut1
1200 Rallycar...It is quite easy to do a wheel alignment without the elaborate setup you see at Jax Tyres or Beaurepairs etc. In Formula Ford it is desireable to do a wheel align after setup changes but not necessary. All it takes is a clamp to fit on the rims of the front and back wheels and a string to determine by the use of a rule to see how far the front wheels are out in comparison to the back ones.
andos
Posted: 2003/5/4 12:07  Updated: 2003/5/4 12:07
 Re: adj strut1
Yeah, actually l did the design using Pro Engineer. Which could easily be considered one of the best cad packages, along with ideas and unigraphix.
I tried to post the pics, but it never works for me!!!
I tried to make it simple to machine, but l also wanted it to be really durable. For this reason it is slightly over engineered, but l like it better this way.
If l find my notes, l'll be able to tell you the amount of camber and castor it allows. They were pretty extreme amounts!!
Posted: 2003/5/4 18:47  Updated: 2003/5/4 18:47
 Re: adj strut1
Where can this "clamp" be purchased? Any more details on this, like a photo?
1200rallycar
Posted: 2003/4/26 14:54  Updated: 2003/4/26 14:54
 Re: adj strut1
note: blue area is thread, and green bottom spring perch turns on this giving adjustable ride height also
1200rallycar
Posted: 2003/4/26 14:56  Updated: 2003/4/26 14:56
 Re: adj strut1
is it true what they say???
i was told that everytime you make adjustments to the suspension you really should go and get a wheel alignment to make sure everything is matched up and stuff? do people actually do this or is this just "ideal"
