Main : Misc : Tech Section Dellow Enginerring Nissan A to Toyota T50 bell housing
[<   Previous  526  527  528  529  530  531  532  Next   >]
Dellow Enginerring Nissan A to Toyota T50 bell housingPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2003/4/27 5:17    Tell a friendTell a friend
Hits9891  Comments13    0.00 (0 votes)0.00 (0 votes)
Dellow Enginerring Nissan A to Toyota T50 bell housing (compilation of Flyby's pics).
stirlingmac
Posted: 2003/4/28 11:49  Updated: 2003/4/28 11:49
 Re: Dellow Enginerring Nissan A to Toyota T50 bell housing
I've just posted a lovely example of what happened to the floor of my racecar when the clutch exploded.... Bang !!!
dattoman_1000
Posted: 2003/4/28 12:47  Updated: 2003/4/28 12:47
I was joking about the damage it could do.
I'm quite attatched to my testicles so I will be making sure I have sufficient protection around the clutch assy.
ang94541
Posted: 2003/4/28 7:51  Updated: 2003/4/28 7:51
How would someone in the USA (hydraulic clutch) install this? Or is a similar conversion available here?
Posted: 2018/5/3 11:04  Updated: 2018/5/3 11:04
Good question. No one has bothered to anser and I'm guessing the reason is that Datsun 5-speeds are fairly common here and less expensive than in Dellow country (Australia)
All LHD 1200 (Germany, Portugal, Canada, etc.) use a hydraulic clutch I believe so the question is big. With a standard Datsun transmission, LHD and RHD use the same gearbox except:
* The LH hole is cut out (all RHD gearbox have the casting outline for this)
* It uses a different release lever (release bearing is the same)
* A slave cylinder is bolted on
See tech article Converting Cable Clutch to Hydraulic
So probably the Dellow bell can be treated the same:
* Cut hole in appropriate location
* Drill & tap a boss for the slave cylinder. You could build up a boss with JB-Weld, the tap the threads into the case. I think this would be strong enough
* RHD & LHD release levers use the same ball stud inside the bellhousing so no worries there
vixen
Posted: 2018/5/4 7:30  Updated: 2018/5/4 7:30
You are right on the money DD the aus Dellow bell housing is only made for mechanical cluch.And you are right 5 speeds are dime a dozen in USA.Us poor aussies only got the 4 speeds and other crap yuo guys didn't want haha.
D
Posted: 2003/4/27 8:56  Updated: 2003/4/27 8:56
From: under the Firmament LOL no twiglight effect BS
i wonder if the lever fits the original gearstick hole. D1000man do you know if your t box slides in the original hole of the 1000???
dattoman_1000
Posted: 2003/4/27 13:21  Updated: 2003/4/27 13:21
Mines being used in a race car so no idea on the orignal hole position. Since my gearbox is behind me and the flywheel is level with my nuts.
dattodude
Posted: 2003/4/27 13:32  Updated: 2003/4/27 13:32
Don't you worry about your flywheel exploding, or the clutch pressure plate exploding..I wouldn't like my nuts in line with those bits...
Chris.
dattoman_1000
Posted: 2003/4/27 13:38  Updated: 2003/4/27 13:38
Thats the reason why I had an alloy one made up rather than lightening a cast unit.
I have an explosion/scatter sheild also which is quite thick and heavy just in case.
Besdies how much damage could a clutch assy doing 9500 rpm do ????
Demojob
Posted: 2003/4/27 13:59  Updated: 2003/4/27 13:59
I have the 3T toyota alloy split case witht e dellow bellhousing and the wick is about 1.5" shorter then the original.
Cheers
damo
dattodude
Posted: 2003/4/27 14:08  Updated: 2003/4/27 14:08
I know you are joking...but I can picture a really loud bang, then a warm sticky sensation running down my side, inside my shirt. I turn and realise that my left hand is still grasped to the gear shifter, but the rest of my arm lies across the passenger seat...not nice..
I've seen flywheels explode on the quarter mile @80+ mph, The car had both it's front brake lines sheered off by the flying pieces. It was a mazda..but still. He must have had a passion for handbrake turns, and his handbrake worked properly. It really turned into an E-brake. Brown underpants stuff..
Posted: 2003/4/27 17:58  Updated: 2003/4/27 17:58
There is detailed information about this swap, prices, mods needs, shifter location etc. in the Tech Section article 5-speed Overview .
One thing it doesn't mention is how scatter-resistant the Dellow housing is. US drag racing associations require a "scatter-shield" bell or a "blanket" when the car gets to a certain speed. The blanket will catch the shattering pieces before they cut brake lines or somebody's body.
D
Posted: 2003/4/28 4:10  Updated: 2003/4/28 4:10
Ive heard similar horror stories that were true. Crap a shatter or scatter blanket would be wise. Always use new rod bolts and dont let some lazy mechanic install your machined flywheel and clutch.
