Main : Mechanical : Engine G18 ENGINE
[<   Previous  2705  2706  2707  2708  2709  2710  2711  Next   >]
G18 ENGINE
G18 ENGINEPopular
SubmitterferalMore Photos from feral   Last Update2003/5/14 2:12    Tell a friendTell a friend
Hits7393  Comments5    0.00 (0 votes)0.00 (0 votes)
This shot shows a set of L series extractors up against the exhaust ports. Port spacings are identical only flange changes are needed to adapt the extractors.
L18_B110
Posted: 2003/5/14 6:19  Updated: 2003/5/14 6:19
 Re: G18 ENGINE
G18 - is that the prince engine?
D
Posted: 2003/5/14 12:35  Updated: 2003/5/14 12:35
From: under the Firmament LOL no twiglight effect BS
 Re: G18 ENGINE
Whats going on here feral these heads if im not mistaken look the same as z18 and ca20 heads like you said. Thats quite abusing for prince and to think George Fury will always remain in the record books with the fastest lap at bathurt in that monstrous turboed underdog bluebird z18 with this head design making nissan look grand. If bathurst didnt change the track it probably still stand?
Feral how do these heads flow compared to non crossflow L heads??
feral
Posted: 2003/5/15 0:12  Updated: 2003/5/15 0:12
 Re: G18 ENGINE
Yes this is the Prince engine, It does look the same as the Z18 head except the dissy drive is off the end of the cam gear. Rocker gear looks the same but the ports on the G18 are sperated same as L series and the Z exhaust ports are bunched together 1,2 and then 3,4.
I have been trying to post more pics but I am having trouble getting them to upload?
D
Posted: 2003/12/10 0:38  Updated: 2003/12/10 0:38
 Re: G18 ENGINE
Just found another engine that we are missing in this forum well I searched and no one has put it up.
Its the GA16DE which is from a jap and U.S. sentra and it can produce alot of goodies.
Could the g18 with z18 exhausts or Z18 update`s great great great grandson???
With a crank angle sensor the dizzy prob would be solved. I read somewhere one can be made up like electromotives one with coil packs and Lada bosh bits but cant remember where? ;{{
http://www.sentra.net/tech/garage/engine.php?S=5979364c9e03cb690a1ad1be190aca2d#Exhaust%20Systems
Posted: 2003/12/10 3:54  Updated: 2003/12/10 3:54
 Re: G18 ENGINE
The GA-series engine has been discussed here for example:
oddball engine swaps
club article What's the best engine to put into a 1200?
matbighat
Posted: 2003/12/10 4:35  Updated: 2003/12/10 4:35
 Re: G18 ENGINE
Some more pics ...
G18/20 came in C30 Laurel
