Main : Mechanical : Engine Red Rocker Shaft
[<   Previous  2154  2155  2156  2157  2158  2159  2160  Next   >]
Red Rocker Shaft
Red Rocker ShaftPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2007/11/17 7:39    Tell a friendTell a friend
Hits3019  Comments9    0.00 (0 votes)0.00 (0 votes)
stylish
1200coupe
Posted: 2007/11/19 8:08  Updated: 2007/11/19 8:08
 Re: Red Rocker Shaft
They also increase the oil pressure to the rocker shafts in high rpm motors.
Pendles
Posted: 2008/7/10 8:13  Updated: 2008/7/10 8:13
Anyone who has had some experience with this or a similar setup:
What kind of end-clearance wound be required between these collars and the rockers, and what kind of shaft clearance internally for oil pressure?
Would it be worthwhile machining some up out of ally stock, or would brass be better.
Might have a crack at making some
Dodgeman
Posted: 2008/7/10 10:30  Updated: 2008/7/10 10:30
Poster: 1200coupe Date: 2007/11/19 18:08:36
Now that IS interesting. I wonder if you could explain in detail how that happens & where you measure the pressure to demonstrate that it really does.
Pendles
Posted: 2008/7/11 0:39  Updated: 2008/7/11 0:39
Question answered here:
Rocker Spacer Discussion
pepper
Posted: 2008/7/11 3:26  Updated: 2008/7/11 3:26
that link dont explain anything about answering the question??
sunny_coupe110
Posted: 2007/11/17 8:58  Updated: 2007/11/17 8:58
Thank you ddgonzal !
killer1200
Posted: 2007/11/17 9:52  Updated: 2007/11/17 9:52
there bushs to remove the springs for high rpm motors.
sunny_coupe110
Posted: 2007/11/17 10:28  Updated: 2007/11/17 10:28
Hello,
This engine turns around over 10000rpm.
