Main : Mechanical : Engine Block Heater Instructions
[<   Previous  2055  2056  2057  2058  2059  2060  2061  Next   >]
Block Heater InstructionsPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2008/1/24 17:29    Tell a friendTell a friend
Hits2494  Comments11    0.00 (0 votes)0.00 (0 votes)
You know you want one.
cheater_5
Posted: 2008/1/25 6:02  Updated: 2008/1/25 6:02
 Re: Block Heater Instructions
what will they think of next...
A14force
Posted: 2008/1/25 6:35  Updated: 2008/1/25 6:35
Warm engines wear much slower than cold ones. I wonder If using one of these would mean you could run it hard straight away? Is this a jdm thing?
Posted: 2008/1/25 6:50  Updated: 2008/1/25 6:50
Naw, this is a "official" Datsun USA Accessory part. They are mostly used in extreme cold climates, e.g. Alaska and Minnesota where temps can reach -40 F (below freezing temperature of anti-freeze).
Although in mountain areas everywhere they are occasionally used. Maybe even in Australia -- does who_your_datty_1200 have one in his Snow Cruiser?
Mountain Rescue
DatsunSSS
Posted: 2008/1/25 12:40  Updated: 2008/1/25 12:40
Here in Portugal we dont use this kind of acessorys.
We have a moderate weather.
And i dont have the cable to turn it on.
110v isnt it?
dattodude
Posted: 2008/1/25 12:59  Updated: 2008/1/25 12:59
nah.. never seen one in Australia. Our snowy mountain rarely get below -10. Nothing like Minnesota.
Although I was once in Minnesota for work at -40degC and the 2003 Chevy Cavalier started everytime. I could pull on the handbrake, turn the front wheel full lock and floor it in reverse to 'spin out' of my parking spot on the icy/snowy concrete. A couple of times, I had to wait for the ice sheet on the inside of the windscreen to clear before I could drive anywhere. The lake would form in the rubber snow mats in the foot wells. That's crazy living there in winter.
A14force
Posted: 2008/1/25 20:48  Updated: 2008/1/25 20:48
NO, Blair (WYD1200) doesn't have one. There are only a few (habatable) parts of NZ where you would need one. Last winter on the news they showed one godless sh1t hole where the diesel was freezing in peoples utes and stuff.
There used to be a kid down the road from me growing up, who's dad had a T-bird which he used to plug in. Kind of a wank really, when you consider it was warm enough to run around in bare feet.
Wombat_racing
Posted: 2008/1/26 1:41  Updated: 2008/1/26 1:41
the old mine rescue ambulance we had at work used to have a engine warmer. that way u could just jump in and go Im sure it was also set up with a trickle charger for the batterys as well.
b310gx
Posted: 2008/1/25 4:19  Updated: 2008/1/25 4:19
for use in a cold climate. Obviously you fit it into one of the welch plugs so it sits in the coolant, & when it's below freezing, you turn it
on to heat the coolant before starting. Or maybe you keep it turned on all night so the coolant doesnt freeze & split the block.
DatsunSSS
Posted: 2008/1/24 18:37  Updated: 2008/1/24 18:37
i have one
Posted: 2008/1/25 5:50  Updated: 2008/1/25 5:50
DatsunSSS' is the one I remember, we had some questions about it a few months ago.
