Main : Misc : Tech Section H145 v's H165 - the differences
[<   Previous  517  518  519  520  521  522  523  Next   >]
H145 v's H165 - the differencesPopular
SubmitterBrentMore Photos from Brent   Last Update2003/6/21 1:04    Tell a friendTell a friend
Hits12372  Comments8    0.00 (0 votes)0.00 (0 votes)
Ok, I
Posted: 2003/6/21 3:16  Updated: 2003/6/21 3:16
 Re: H145 v
Excellent work. Thanks Brent, people have been asking about this for a long time.
The diameter of the tubes would be per calculation:
H145: 54mm (2-1/8 in)
H165: 62mm (2-1/2 in)
The H150 diff also has bolts, but is about the same size as the H145, so measure to be sure. All have 8 bolt holes.
ANGE
Posted: 2003/6/21 3:28  Updated: 2003/6/21 3:28
 Re: H145 v
.....at last!
H165 it is :)
thanks heaps...
2332owner
Posted: 2003/6/21 6:55  Updated: 2003/6/21 6:55
 Re: H145 v
Thanks Brent... exactly what we needed!
dattodude
Posted: 2003/7/27 11:41  Updated: 2003/7/27 11:41
 Re: H145 v
Brent or others..
What are the axle differences between the H165 and the H145.
Or more clearly.. Can H145 Axles be used in a H165 Diff? We know the H165 ones are larger, but do they have the same length, wheel bearing, and axle spline?
Cheers,
Chris
D
Posted: 2004/12/7 22:18  Updated: 2004/12/7 22:18
From: under the Firmament LOL no twiglight effect BS
 Re: H145 v
Bump
DD did you mean the axles are those measurements?
Brent
Posted: 2004/12/7 22:59  Updated: 2004/12/7 22:59
 Re: H145 v
I'm sure its the axle tubes that are those dims.
D
Posted: 2004/12/8 1:30  Updated: 2004/12/8 1:30
 Re: H145 v
So are axles the same?
can the centre be changed?
The first h165 diffs on the s1 bluebird of 67 has bigger drums and beautiful alloy hat.
Brent
Posted: 2004/12/8 3:41  Updated: 2004/12/8 3:41
 Re: H145 v
No axles & centres are different - bigger.
Don't know the S1 Bluebird.
