Main : Misc : Tech Section VISUAL SEX
[<   Previous  520  521  522  523  524  525  526  Next   >]
VISUAL SEX
VISUAL SEXPopular
SubmitterferalMore Photos from feral   Last Update2003/6/3 11:12    Tell a friendTell a friend
Hits5228  Comments5    0.00 (0 votes)0.00 (0 votes)
Just got the race head back after extensive chamber and port work and new valves. Beware this should not be viewed by minors or the faint of heart
Dodgeman
Posted: 2004/1/15 21:14  Updated: 2004/1/15 21:14
 Re: VISUAL SEX
Unless I miss my guess, this head is a 1200 [compatible] item. That hole below the center head bolt looks to be the oil feed to me.
It should work fine, without modification, on all of the 1974 & newer blocks
B120dat
Posted: 2004/1/15 11:20  Updated: 2004/1/15 11:20
 Re: VISUAL SEX
Inlet valves are 40mm and exhausts 33mm. Valve stems are fitted with "Roto" caps. The combustion chambers are shaped to promote quick charge burn. All galleries are opened up for better coolant flow.
This is errols *aka Feral* A13 motor. very very awsome motor to find out more info about this motor and other kool stuff he has, go to : www.datrats.com.au
Tumulus
Posted: 2004/1/15 11:02  Updated: 2004/1/15 11:02
 Re: VISUAL SEX
wow, really, really nice...
good looking
Quinn
Posted: 2004/1/15 11:07  Updated: 2004/1/15 11:07
 Re: VISUAL SEX
how big are those valves? is this an a12 head or an a14GX? (oval or round ports?)
ca18det_man
Posted: 2004/1/15 12:34  Updated: 2004/1/15 12:34
 Re: VISUAL SEX
Now I have seen this work of art how do i stop this fluid ruinning from my mouth???? Ill be drooling for weeks.
Whats next for the mighty A series errol?? have you chosen a camshaft and rockers ect??
cheers Andrew
tsillay
Posted: 2004/1/15 20:12  Updated: 2004/1/15 20:12
 Re: VISUAL SEX
yummy......
Love the chamber shape....dying to know how it goes....
A few welding filler rods died to make this one...!
