Main : Misc : Tech Section hidraulic brake service parts
[<   Previous  192  193  194  195  196  197  198  Next   >]
hidraulic brake service partsPopular
SubmitterDatsunSSSMore Photos from DatsunSSS   Last Update2008/11/11 19:31    Tell a friendTell a friend
Hits1944  Comments4    0.00 (0 votes)0.00 (0 votes)
Sankyo Automotive Co.Ltd
Made in Japan
Part  number 41120-28525
DatsunSSS
Posted: 2008/11/11 22:47  Updated: 2008/11/11 22:47
 Re: hidraulic brake service parts
Any sujestions how to install it?
Posted: 2008/11/12 3:10  Updated: 2008/11/12 3:10
1. Pull the pistons out of the calipers
2. Remove old seals, fit new seals
3. Reinsert pistons
4. After air bleed procedure, fit the new caps to the valve
Note that the stock Datsun 1200 disc-brake calipers are two-piston type. Good stuff.
PIGDOG
Posted: 2008/11/12 5:07  Updated: 2008/11/12 5:07
probably want to give the calipers a good clean whilst the old seals are out, and even hit the bores with some fine wet and dry to get rid of any crap that way be on the caliper bore walls
