Main : Misc : Tech Section broken gearbox
[<   Previous  193  194  195  196  197  198  199  Next   >]
broken gearbox
broken gearboxPopular
SubmitterDatsunSSSMore Photos from DatsunSSS   Last Update2008/12/11 20:06    Tell a friendTell a friend
Hits3480  Comments7    0.00 (0 votes)0.00 (0 votes)
One bearing is completelly destroyed !!!
How can i see if the syncros are bad?
the 2 and the 3 gear didnt shift very well , thats why i say the syncros are bad, but that problem could be the cause wend the bearing started to crack??????
Asblik
Posted: 2008/12/12 3:21  Updated: 2008/12/12 3:21
Not too shy to talk
 Re: broken gearbox
Put the syncro on the gear. Put a bit of pressure un the syncro and turn it. If the syncro turn free it is bad. The syncro must have a bit of grip on the gear when you turn it.
Regards
revhead001
Posted: 2008/12/13 7:42  Updated: 2008/12/13 7:42
 Re: broken gearbox
The bearing you are pointing at is a tapered roller bearing. When you pulled the front nosecone off was there a shim for the layshaft? It is unusual for a tapered roller to completely destroy itself when it has proper endfloat.
Edit. My bad. Thinking of the 63a dogleg.
datski620
Posted: 2008/12/13 8:00  Updated: 2008/12/13 8:00
 Re: broken gearbox
i hate gearboxes with a passion.....stupid bearings. when my old 4 spped went the reverse snapped into 3 and ate the rest of the gears while it was at it. All i could see when i drained the oil was chunks of metal, so i handed in the gearbox for a swap for a new one. felt better i didnt have to look at it
Posted: 2008/12/13 8:56  Updated: 2015/10/13 3:20
 Re: broken gearbox
That's first gear. In the 56 5-speed it is a ball bearing.
32223-H7200 BEARING-ball, counter shaft
56-series 5-speed gearset
DatsunSSS
Posted: 2008/12/13 19:22  Updated: 2008/12/13 19:22
 Re: broken gearbox
yes it is a bearing ball.
thanks DD
weere did you get this image?
do you have the entire manual of my gearbox?
Posted: 2008/12/13 20:19  Updated: 2008/12/13 20:19
 Re: broken gearbox
hi dsss, it is from the parts catalog. I do not have the repair manual.
Posted: 2015/10/13 3:14  Updated: 2015/10/13 3:18
 Re: broken gearbox
Seems like the only common way for the ball bearing to go bad is low oil (lack of lubrication). Although if the wrong thickness thrust washer is installed, it might suffer from side movement.
More detail on this part:
Counter Gear
