Main : Mechanical : Engine B110SSS turbo engine
[<   Previous  2718  2719  2720  2721  2722  2723  2724  Next   >]
B110SSS turbo enginePopular
SubmitterL18_B110More Photos from L18_B110   Last Update2003/10/19 22:39    Tell a friendTell a friend
Hits6236  Comments5    8.50008.50 (2 votes)
EFI turbo A14. well laid out and purposeful engine bay.
posting these photos for B110SSS
B120dat
Posted: 2003/10/20 1:32  Updated: 2003/10/20 1:32
 Re: B110SSS turbo engine
WOW! thats is great! great job makes me wanna turbo/efi mine
what power is this putting out? (ever done QM)
what turbo? (psi?)
cheers
p.s beautitfullllllllll motor
L18_B110
Posted: 2003/10/20 2:08  Updated: 2003/10/20 2:08
It's B110SSS's car, but some of your answers are in the a15ett to run 12's??? discussion.
B110SSS wrote:
The car ran 13.7@ 107mph
not bad at all! And it looks right at home on the racetrack too as you'll see in the other photo
Quinn
Posted: 2003/10/20 6:52  Updated: 2003/10/20 6:52
would you happen to know what radiator its got? looks good.
B110SSS
Posted: 2003/10/20 8:30  Updated: 2003/10/20 8:30
Leyland P76 ( overkill!)
1200rallycar
Posted: 2003/10/20 11:49  Updated: 2003/10/20 11:49
can you explain the setup, what is the big box up the front left? is it like a plenum??? is it intercolled ect ect, what is the thing on the front right, an oil cooler?
and that is the weirdest looking bov ive ever seen
otherwise, yeah looks awesome, im drooling
B110SSS
Posted: 2003/10/21 5:26  Updated: 2003/10/21 5:26
1200RC
Firstly, this was built up some 12 years ago so big evo type intercoolers were not around.
The 'box' thing on the left is ducting for a Starion turbo intercooler. You are coorect about the oil cooler on the right - ex a Cessna aircraft I believe ( came out of my rally car)
Re the bov, remember this is 12 yeras ago- its a pheumatic bellows- works in exactly the same way.
The setup is very simple- the turbo is mounted on a 'j' bend ex a standard cast exhaust manifold.-efficient, strong and not prone to cracking.
The inlet, 4 x 40 hp Nissan Bluebird injectors with a big ECI Mitsi one up front of the throttle body.
Fuel only Link ecu.
Dist set at max. 30 degees advance.
Hope that answers a few of your questions.
Regards
