Main : Mechanical : Engine hpc coated pistons
[<   Previous  1578  1579  1580  1581  1582  1583  1584  Next   >]
hpc coated pistons
hpc coated pistonsPopular
SubmitterA14forceMore Photos from A14force   Last Update2009/10/10 0:31    Tell a friendTell a friend
Hits4604  Comments9    0.00 (0 votes)0.00 (0 votes)
Here are the mazda E5 pistons I'm using for my latest A15 build. I just got them back from high performance coatings limited www.hpcoatings.co.nz/pistons.htm .
They have applied a thermal barrier coating to the crowns, and another kind of film to the skirts of the skirts.
Using these pistons also reguired me to have the small ends of my conrods enlarged to take the 20mm mazda gudgeon pins. (I hope like hell this doesn't make them weaker!)
LittleFireyOne
Posted: 2009/10/11 11:31  Updated: 2009/10/11 11:31
 Re: hpc coated pistons
had a thought and looked it up A14\15 vs CA18 rod, why not go with that for the rod now the gudgeon is bugger...I meant bigger :P
Posted: 2009/10/11 20:27  Updated: 2009/10/11 20:27
naw, A12 is 17.45mm diameter gudgeon pin, A14 pin is 19.00mm.
LittleFireyOne
Posted: 2009/10/12 1:41  Updated: 2009/10/12 1:41
exactly, mazda gudgeon pin size is 20mm and ca18 rod is 20mm instead of the A14\A15 19mm one. You got a thread on this A14force?
D
Posted: 2009/10/12 4:46  Updated: 2009/10/12 4:47
From: under the Firmament LOL no twiglight effect BS
prices please
clyons8
Posted: 2009/10/12 7:05  Updated: 2009/10/12 7:05
Non stick Teflon pistons next to a non stick Teflon pan.
Something doesn't fit.
LittleFireyOne
Posted: 2009/10/14 3:28  Updated: 2009/10/14 3:28
Ah I see what you mean. Are you using A12 rods because of the height of the piston?
A14force
Posted: 2010/1/4 3:36  Updated: 2010/1/4 3:36
I just saw a bunch of questions on this pic,
It cost around $200 to have both the thermal barrier on the crown, and the slipery stuff on the skirts.
I didn't use the CA16de rods (I do have a set, and they are a bit lighter than the ca18 ones) becuase they are a floating pin, and I couldn't be bothered having the pistons machined to accept the clips needed when running a floating pin. Plus my A15 rods had already been balanced, and I couldn't justify the extra cost of having the CA rods balanced.
steveo
Posted: 2009/10/11 9:19  Updated: 2009/10/11 9:19
how much did the coating cost to get done?
