Main : Members : ang94541 stock 1200 strut
[<   Previous  49  50  51  52  53  54  55  Next   >]
stock 1200 strut
stock 1200 strutPopular
Submitterang94541More Photos from ang94541   Last Update2002/8/18 8:31    Tell a friendTell a friend
Hits6186  Comments4    0.00 (0 votes)0.00 (0 votes)
this is how much needs to get cut off to use a KYB 361005 VW Jetta insert. about 4"/100mm. A threaded collar is added to the end.
ang94541
Posted: 2007/8/27 13:22  Updated: 2007/8/27 13:22
 Re: stock 1200 strut
because that's what popped out when I opened up a pair of used, modified struts that came with the purchase of 1200.
I bought this used 1200 that came with a few buckets of parts, including a couple of pairs of struts. I didn't even notice they had been modified untill I tried to rebuild them several months later.
edit: I'm not sure about the valving. I'm sure you're right, but for street driven it's fine.
Curtis
Posted: 2007/6/12 12:24  Updated: 2007/6/12 12:24
any one know the differences in stroke between this insert and the stock one cheers..
Posted: 2007/8/27 8:30  Updated: 2007/8/27 8:30
To use the Jetta insert, couldn't you just put a spacer in the bottom of the strut tube?
Of course, if your goal is to lower the 1200 at the same time, then does cutting the tube down make it possible?
Quinn
Posted: 2007/8/27 10:30  Updated: 2007/8/27 10:30
Why a VW Jetta shock? surely being FWD and a different weight, it would be valved completely wrong for a 1200 (bump and rebound).
