Main : Mechanical : Engine oil cooler kit + parts bought for engine
[<   Previous  2582  2583  2584  2585  2586  2587  2588  Next   >]
oil cooler kit + parts bought for enginePopular
SubmitterevilsimMore Photos from evilsim   Last Update2004/12/6 13:33    Tell a friendTell a friend
Hits4147  Comments3    0.00 (0 votes)0.00 (0 votes)
ive been gathering bits for my A15 which is almost completed. here are a few of them.
from top left.
-oversize piston
-a15 oval ports on twin weber manifold (already sold to kegs)
-timing kit, bearings, valve stuff, gaskets, water pump
-fuel pump
-oil cooler kit
- sandwich plate, radiator, high pressure hose
the oil cooler fits perfectly inside the front apron, bolted to the engine body. looks like it will fit with the airdam on there too.
I'll power the fuel pump from the oil pressure switch, instead of on ignition.
A14force
Posted: 2004/12/6 23:09  Updated: 2004/12/6 23:09
 Re: oil cooler kit + parts bought for engine
to do that to your fuel pump , you will need to get a relay which has an "energised open" circuit.
Otherwise you will only have fuel pressure when there is no oil pressure.
evilsim
Posted: 2004/12/7 6:00  Updated: 2004/12/7 6:00
thanks i wasnt 100% sure if i should use one or not.
i want fuel pressure when there is oil pressure (when the dash oil lights turns off just after the car starts) so am i going to connect a (+) trigger relay to the oil pressure switch, then run the 12v output of the relay to the fuel pump.
i guess that when im trying to start the car on cold mornings, before there is oil pressure, there will be enough fuel in the webers' floats to get em going..?
1200rallycar
Posted: 2004/12/7 10:11  Updated: 2004/12/7 10:11
yeah id say you would be fine, maybe an overide switch would help, as if you dont drive it for a week the fuel may all evaporate out
are you upgrading the oil pump for the cooler or do you think its safe with the stock
evilsim
Posted: 2004/12/9 8:10  Updated: 2004/12/9 8:10
 Re: oil cooler IN AT LAST
i am sticking with a stock oil pump from my A15. Hope it is sufficient. i cant find its pumpage volume in any of my 1200 manuals.
An override switch is a good idea I know just the place for it too. cheers
edit:
oil cooler is in! just piped it all up tonight. I had a temperature sender for a guage put into the sandwich adapter, so it reads engine oil temp straight out of the engine. The piping you see in this picture was not the piping I used. I ended up getting huge 16mm bits and changing it all to 16mm pipe. Good strong 300psi pipe, very rigid, but surprisingly it bent into place easily. Initially, the empty oil cooler filled up very quickly (only idle'd about 15seconds before i could feel hot oil flowing into the oil cooler for the 1st time), a good demo of the old A series stock oil pump! still retaining 10-30psi idle and 40-60 above 3000rpms. The oil temperature took a while to warm up but stayed steadily coming out of the motor at 80-90 celcius while highway driving, and 60-80 while city driving.. all with my 4 speed gbox. (3500-4000rpm highway driving)
