Main : Mechanical : Engine DAT-186
[<   Previous  2579  2580  2581  2582  2583  2584  2585  Next   >]
DAT-186
DAT-186Popular
SubmitterDato1000More Photos from Dato1000   Last Update2004/12/28 7:24    Tell a friendTell a friend
Hits5089  Comments11    0.00 (0 votes)0.00 (0 votes)
supercharged 186 holden 6 in datsun 1000 ute
COUP1200
Posted: 2004/12/30 0:32  Updated: 2004/12/30 0:32
 Re: DAT-186
Why?
D
Posted: 2004/12/30 8:40  Updated: 2004/12/30 8:40
From: under the Firmament LOL no twiglight effect BS
 Re: DAT-186
How did you make the gearcharger??!!
Can you teach us how you made it in detail?
I had this in mind for a t04 hybrid
TnPshow
Posted: 2004/12/31 7:25  Updated: 2004/12/31 7:25
 Re: DAT-186
Yeah that's a custom SC made from a turbo - I've seen other pics of this car elsewhere...
The exhaust housing has been removed and the drive pulley bolted on in its place as far as I can tell:
TC
kegs
Posted: 2004/12/31 9:35  Updated: 2004/12/31 9:35
 Re: DAT-186
to me it looks as though the pulley ratio going to the turbo/supercharger doesnt look high enough to really get it spinning.it doesnt have a step up gearbox to get it going so i wonder how much of a advantage this thing gives??? prove me wrong id like to hear how it goes, just doesnt seem as though it wouldf be spinning quick enough to make much boost ???
D
Posted: 2005/1/1 12:04  Updated: 2005/1/1 12:04
 Re: DAT-186
looks like the pulley is small enough to get it spinning fast enough but maybe if turbos need to spin at 30-50,000rpm then its a problem.
datrat_dave
Posted: 2004/12/29 22:08  Updated: 2004/12/29 22:08
 Re: DAT-186
What the hell is with the S/C setup here??
That pulley looks like its going no where...
Any info on this setup?
BACKFIRE
Posted: 2004/12/29 23:51  Updated: 2004/12/29 23:51
 Re: DAT-186
After a second look, yes Holley or Weber 32/36 (I think they are the same anyway).
BACKFIRE
Posted: 2004/12/29 1:16  Updated: 2004/12/29 1:16
 Re: DAT-186
That's an interesting belt setup and SC location. I assume that's a Vortex type SC.
Any idea of what kind of boost pressure this set up develops? Is that a standard single barrel downdraft carb?
We need details!
converted
Posted: 2004/12/29 10:04  Updated: 2004/12/29 10:04
 Re: DAT-186
two words, thats wrong.....
Freak
Posted: 2004/12/29 10:44  Updated: 2004/12/29 10:44
 Re: DAT-186
Im pretty sure that is not a stock carby. Looks like a 350holley on redline manifold.
Dato1000
Posted: 2005/7/22 16:28  Updated: 2005/7/22 16:28
Quite a regular
 Re: DAT-186
At 6800 engine RPM the blower is spinning at 140,000 Rpm, that whats it worked out to be, after it goes the the alternator then to another puller attached to the alternator the same size as the harmonic blancer then to another pulley the same size as the alternator. the carby is a 350 holley on a redline manifold.
i just made this set up out of stuff I had spares of, so if it doesnt work it doesnt bother me, i havent even bothered finisheing the blower yet as the ute cant even get traction as it is.
ANGE
Posted: 2005/7/23 3:30  Updated: 2005/7/23 3:30
 Re: DAT-186
looks like you have a blanket for a firewall
Dato1000
Posted: 2005/7/23 15:51  Updated: 2005/7/23 15:51
Quite a regular
 Re: DAT-186
lol, No its all fire proof matting, that goes all under the alloy trans tunnel. just to keep me safe.
