Main : Mechanical : Engine Plugs and Leads
[<   Previous  2576  2577  2578  2579  2580  2581  2582  Next   >]
Plugs and Leads
Plugs and LeadsPopular
SubmitterdattodevilMore Photos from dattodevil   Last Update2005/1/31 5:52    Tell a friendTell a friend
Hits3048  Comments9    0.00 (0 votes)0.00 (0 votes)
Got some new plugs and leads, can get rid of those original copper leads. These will compliment the high output coil and electronic dizzy
Dodgeman
Posted: 2005/2/3 23:01  Updated: 2005/2/3 23:01
 Re: Plugs and Leads
The Irridums aren't all that costly. Somewhere in the $22 to $25 range should cover it. [each] I bought mine through Repco so they aren't hard to get either
Frodaddy
Posted: 2005/2/3 23:08  Updated: 2005/2/3 23:08
 Re: Plugs and Leads
But compared to the normal plugs pricewise...
snowy
Posted: 2005/2/4 1:12  Updated: 2005/2/4 1:12
 Re: Plugs and Leads
Sorry to hijack this post, but what are the benefits of iridium plugs over normal plugs?
Dodgeman
Posted: 2005/2/4 2:15  Updated: 2005/2/4 2:15
 Re: Plugs and Leads
These things will fire at a lower voltage across a given gap at a given compression pressure, which means that the gap can be opened out a little without taxing the coil, & while they are diong all this, they will outlast $25 worth of regular plugs to boot.
[Comparison is with both types of plugs in identical conditions]
They are not expensive, they are good VALUE, particularly in a high compression, high performance engine.
snowy
Posted: 2005/2/4 2:18  Updated: 2005/2/4 2:18
 Re: Plugs and Leads
Thanks. Sounds to me like a good investment, particularly in a daily driver.
dattodevil
Posted: 2005/2/4 6:10  Updated: 2005/2/4 6:10
 Re: Plugs and Leads
Yeah as Dodgeman said, They only cost me around $15, The manufacture also says that they are self cleaning, but whether this is propaganda or true is still debateable. But all and all its a good investment.
who_your_datty_1200
Posted: 2005/2/4 11:21  Updated: 2005/2/4 11:21
 Re: Plugs and Leads
Did you get them from Pan's or Appco??? Or somewhere else???
dattodevil
Posted: 2005/2/5 3:56  Updated: 2005/2/5 3:56
 Re: Plugs and Leads
Darbi's
Frodaddy
Posted: 2005/2/3 21:42  Updated: 2005/2/3 21:42
 Re: Plugs and Leads
Those iridiums cost a fair bit...
