Main : Members : 1200rallycar Seat rails
[<   Previous  83  84  85  86  87  88  89  Next   >]
Seat rails
Seat railsPopular
Submitter1200rallycarMore Photos from 1200rallycar   Last Update2002/11/12 14:26    Tell a friendTell a friend
Hits3442  Comments7    0.00 (0 votes)0.00 (0 votes)
how i mounted them using original brackets on original mounts, bolted that boxed steel to moving part of rail and added spacer so that the handle to move seat back and forward could still be operated
Datopower
Posted: 2002/11/13 19:59  Updated: 2002/11/13 19:59
 Re: Seat rails
Hey,
I was just wondering what kind of seats have you used here ??
Cheers
1200rallycar
Posted: 2002/11/14 3:42  Updated: 2002/11/14 3:42
 Re: Seat rails
there is a btter pic, they came out of some volvo apparently (dont know if they were standard in that, there was no brand name on seats), Tayell automotive had em sitting in his workshop so i grabbed em, they didnt have harness holes but we just cut them in after recovering (havent done passanger seat yet cause i dont have to sit in that one )
i though about centre of gravity, but ease of install took preference, i might have to do a better job when i fix em up, i guess i rushed too much
phunkdoktaspok
Posted: 2002/11/13 3:17  Updated: 2002/11/13 3:17
 Re: Seat rails
Looks like good work!
But one thing I would like to point out for your own safety and so you don't have trouble with RTA inspections is that when bolting through box tubing engineering requirements state that an anti-crush tube should be fitted! ( basically a sleeve for the bolt but inside the box tube so that the tube can't crush!)
This is a NSW engineering requirement but I am assuming Victoria would be the same!
Also any seat modifications have to be engineer signified!
Just though you might like to check this out!
Cheers,
Steve
benny
Posted: 2002/11/13 4:21  Updated: 2002/11/13 4:21
 Re: Seat rails
I would also keep in mind what tensile bolts you use in this application as well. As im sure you are aware, the bolts you use are the only thing stopping you smacking the wheel\dashboard under heavy braking or worse, a heavy inpact. No comprimize for safety !
I only say this beacause a mate of mine drove around for years (around 5) with a similar setup, but only used mild steel bolts until one day he had a moderate impact with another car. All four bolts snapped clean off.
rally-a-coupe
Posted: 2002/11/13 7:12  Updated: 2002/11/13 7:12
 Re: Seat rails
are adjustable seat rails legal in aus for motorsport use mine are solid mounted ill post a pic tomorrow
1200rallycar
Posted: 2002/11/13 8:29  Updated: 2002/11/13 8:29
 Re: Seat rails
hmm ok, well there plain old bolts and there obviously no sleeves, not sure about adjustable thin, can i possibly do anything else wrong?
nah thanks for pointing that stuff out ill fix it up soone or later
dimlight65
Posted: 2002/11/13 16:16  Updated: 2002/11/13 16:16
 Re: Seat rails
Well, it seems to me you have also raised your center of gravity by adding the extra height. I wasn't going to say anything, but you asked.
