Main : Mechanical : Drive Train Sprinter Diff Conversion
[<   Previous  680  681  682  683  684  685  686  Next   >]
Sprinter Diff ConversionPopular
Submitterrally1200More Photos from rally1200   Last Update2005/5/2 15:07    Tell a friendTell a friend
Hits3713  Comments1    0.00 (0 votes)0.00 (0 votes)
Pic of the Double row wheel bearing i used in the sprinter conversion. This conversion could be used on a standard H165 diff
Dodgeman
Posted: 2006/3/16 5:23  Updated: 2006/3/16 5:23
 Re: Sprinter Diff Conversion
OK, I know that this is an older pic, but certain questions must be asked.
The part number of the bearing?
Is it the standard ID & OD of the original bearing? [I guess it is but need to confirm.]
What rear axle housing did you use it in? [1200 ute, Blurbird etc.]
I presume that it was necessary to machine the bearing bore in the housing a bit deeper. If this is so, then by how much?
Any other info will be much appreciated.
{EDIT} OK, i looked at the other pics. I still presume that this could be done with a Datsun rear axle, would this be correct?
