Main : Mechanical : Drive Train 60 series 5 speed into B110 coupe
[<   Previous  676  677  678  679  680  681  682  Next   >]
60 series 5 speed into B110 coupePopular
SubmitterevilsimMore Photos from evilsim   Last Update2005/6/13 16:08    Tell a friendTell a friend
Hits5830  Comments4    10.000010.00 (1 vote)
A. box with stanza (same as sunny) stock mount
B. showing side view of custom mount
C. showing rear view of mount
read post for more info & shopping list for gearbox swap and problems i ran into doing the swap.
b310gx
Posted: 2005/6/15 12:24  Updated: 2005/6/15 12:24
 Re: 60 series 5 speed into B110 coupe
in place of the washer on the original clutch cable,a 120y or sunny cable works just as well. just beware as some sunny's have a clutch adjustment which is a circlip.avoid these as a heavy clutch clamping pressure can cause the circlip to pop off.bit of a worry when that happens.
evilsim
Posted: 2005/6/13 16:29  Updated: 2005/6/13 16:29
OK first things first. I bought this box from someone who I also payed extra to, to get bearings replaced. After lots of effort gettting it into my coupe, it was a dead cause, the box has a bad main shaft and more. boo hoo i still need to buy one of these gearboxs which WORKS. help me! im currently running a 120Y 4 speed.
shopping list:
Nissan : metal cover between tailshaft and gearbox approx $20 (not shown in undercar pic)
Nissan : rubber boot for clutch fork approx $20 rubber boot for where gearstick engages the box approx $10.
Auto store : stanza / sunny gearbox mount
Auto store : 1 large washer (for clutch cable)
somewhere : FS5W60A gearbox
A: here is where the gearbox sits when bolted onto the engine. as you can see you need to make a custom mount.
B: I copied the U pattern design and ended up using large washers welded together as a spacer. It allows for simple adjustment.
C: see the washers, note one side needs more washers than the other.
problems i ran into:
-broken 5 speed (buyer beware!)
-need to bash the tunnel where the clutch fork pokes out of the gearbox.
-need to use a large washer between gearbox/clutch cable entrance to hold the clutch cable in position.
-needed the little screw which holds the gearstick into the box (5 speed is DIFFERENT from 4 speed box)
-gearbox oil stinks like ####
-make your own reverse switch (normally-ON)
-make your own U shaped mount. I used a thick piece of metal 225mm x 110 and it JUST fit, but fit properly and sturdily.
cheers to all the people who helped me with this swap over and to all the folks who wrote articles about the 5 speed swap and related topics. this website rules for 1200 info.
Lobster
Posted: 2005/6/14 2:16  Updated: 2005/6/14 2:16
I cringe at the thought of changing gearboxes or clutches after my first experience chanign the clutch in my gemini.
The smell of gearbox oil, make me dry retch after that. Can not stand the stuff...
Posted: 2005/6/14 7:39  Updated: 2005/6/14 7:39
Excellent photo collage. It makes it very clear what is needed in the way of making a transmission crossmember for this swap. It's just like mine in the driveway outside.
And it stays in your hair for days ... Yuck.
datrat_dave
Posted: 2005/6/14 9:13  Updated: 2005/6/14 9:13
Im with you ddgonzal, stupid me - when i drained my box i put it in a bucket thing right, thing i didnt know it had a crack now its all in my hair...this stuff stinks ssoooo bad and yes it does make you dry wreetch....ewww
Nice photo dude great detail!
