Main : Mechanical : Engine 5-liter 1200 engine compartment
[<   Previous  2522  2523  2524  2525  2526  2527  2528  Next   >]
5-liter 1200 engine compartmentPopular
SubmitterddgonzalMore Photos from ddgonzal   Last Update2005/6/30 16:00    Tell a friendTell a friend
Hits6576  Comments6    0.00 (0 votes)0.00 (0 votes)
1969 302 cubic inch Ford V8. For standard-size american V8s, the 302 'windsor' engines are very narrow (more so than chevy V8s)
Dodgeman
Posted: 2005/7/1 15:42  Updated: 2005/7/1 15:42
 Re: 5-liter 1200 engine compartment
At 490 Lbs [223 Kg] ready to run, the Winsdor engine is surprisingly light for an iron V8. By switching to alloy intake & cylinder heads, plus a set of headers, it can be made seriously lighter. By carefully selecting the trans, the weight can be kept down to within realistic limits. Actually, the alloy heads are a really good idea as the iron heads don't flow all that well, particularly on the exhaust side, but the alloy ones do.
These engines, without exhaust, are in fact quite narrow, but add an exhaust that breathes & suddenly it's not so narrow anymore.
The real problem with these Ford engines is the length, but if the firewall has to go, then moving it back a bit will help weight distribution. Spending some money on the water pump & its drive can yeild up to 4" [100mm] of length reduction i'm told.
matbighat
Posted: 2005/7/2 3:15  Updated: 2005/7/2 3:15
I just had my A14 lifters radius ground and an old guy volunteered that they resembled old Ford V8 lifters.
converted
Posted: 2005/7/2 8:25  Updated: 2005/7/2 8:25
I still know of one for sale here in sydney good for drag racing...not my cup of Twinings though
evilsim
Posted: 2005/7/1 1:40  Updated: 2005/7/1 1:40
see ya later firewall !!
snowy
Posted: 2005/7/1 2:01  Updated: 2005/7/1 2:01
I note ther'e no exhaust manifold attached. That would make it a REAL tight fit.
Great straight line power. Just don't turn a corner.
anders8b
Posted: 2005/7/1 2:56  Updated: 2005/7/1 2:56
Not too shy to talk
is that the one on sale on ebay... if so by the looks of the back end its not designed to take corners
Posted: 2005/7/1 4:31  Updated: 2005/7/1 4:31
Yes, the eBay listing is discussed here: 5-liter 1200 Coupe for sale - New York, USA
