Main : Misc Tic Toc. KB10 clock
[<   Previous  5074  5075  5076  5077  5078  5079  5080  Next   >]
Tic Toc. KB10 clock
Tic Toc. KB10 clockPopular
SubmitterDodgemanMore Photos from Dodgeman   Last Update2005/8/27 14:12    Tell a friendTell a friend
Hits3479  Comments5    0.00 (0 votes)0.00 (0 votes)
This is the factory option dash mounted clock for KB10's
Dodgeman
Posted: 2005/8/27 14:25  Updated: 2005/8/27 14:25
 Re: Tic Toc. KB10 clock
This wonderfull clock was kindly provided to me by club member TnPshow in South Australia from his treasure chest of parts. [back shed] I want to say thank you very much Terry. Your kindness & generosity is very much appreciated.
These clocks were optional in the JDM KB10 Sunny Coupe, but were never offered in Australia, so finding this one was a very pleasant surprise indeed.
While it is an electric clock, i believe that it actually uses a standard mechanical clock mechanism that is electricaly wound. This is how most pre-digital electric car clocks were, so it should no big a hassle to get it serviced & regulated before it takes pride of place on my dash. The soft tic-toc will be music to my ears.
Pod mounted clocks,...not for ordinary cars.
TnPshow
Posted: 2005/8/27 16:36  Updated: 2005/8/27 16:36
Good to see it go to a good home!
hotrod88
Posted: 2005/8/27 17:45  Updated: 2005/8/27 17:45
my 1200 had a clock in the dash , I removed it and mounted a tach in its place.
Dodgeman
Posted: 2005/8/27 19:03  Updated: 2005/8/27 19:03
The Datsun 1000 coupe [the Aussie version of the KB10] came with a tach in the dash as standard, as did all the Aussie Datsun 1200 coupes. It's the clocks for these that are uncommon & they were mounted in the console.
Speaking of original 1200 clocks,.. does anyone have one that they want to part with?
sidedraught
Posted: 2005/8/28 1:06  Updated: 2005/8/28 1:06
Your not going to drill a hole in your coupe dash are you Dodgeman?
Dodgeman
Posted: 2005/8/28 1:52  Updated: 2005/8/28 1:52
If you look at a KB10 dash with the dash pad removed, you will find that the hole for the clock is already there. It's the same for all B10 models, the metal dash is pre-drilled.
Next, look under the dash mat. There is a hole in the padding that is covered by the skin of the pad itself. This hole conveniently lines up with the one in the metal dash. It seems to be only a matter of cutting through the skin to access the factory provided mounting point.
When i have the dash pad redone, i will get the hole opened up & have the skin folded over to line the hole. Unfortunately my dash pad has had a base for what i presume to have been some religous medalion glued to it. The glue has destroyed a two inch square patch of the skin on the pad material & ruined an otherwise blemish free dash pad.
Clever, & thoughtfull, little chaps those Datsun engineers. Just another reason why it's no ordinary car.
