Main : Misc Dazza's ute with new plates
[<   Previous  5071  5072  5073  5074  5075  5076  5077  Next   >]
Dazza's ute with new platesPopular
SubmitterdazzasuteMore Photos from dazzasute   Last Update2005/8/29 13:32    Tell a friendTell a friend
Hits3270  Comments7    0.00 (0 votes)0.00 (0 votes)
got me new plates at last!!!
dazzasute
Posted: 2005/8/29 13:33  Updated: 2005/8/29 13:33
 Re: Dazza
figured it was about time i put in an updated pic...
spent about 6 hours on it today, cutting it back with 1200 grit wet and dry, and then polishing. Well worth the time
Freak
Posted: 2005/8/29 13:40  Updated: 2005/8/29 13:40
 Re: Dazza
Looks good mate. Love the plates too. There the sort of plates Id expect to have alreay been taken.
What gear does it light up with the l20 in it?
dazzasute
Posted: 2005/8/29 13:45  Updated: 2005/8/29 13:45
 Re: Dazza
with me old tyres i couldn't take off on a wet day, when it was on a slight hill....
I've put hankook K26's on it now, 195/60 R14. They stick waaaaay better!
still manages to chirp when i dump it at around 70km/h in the dry though.
Saving up to do some more work to the motor. At the moment its stock as a rock with a single webber extractors and 2 inch exhaust.
Freak
Posted: 2005/8/29 13:55  Updated: 2005/8/29 13:55
 Re: Dazza
70km/h chirp it alright still. The mild/hot a14 I have chirps second hard enough that it kicks sideways abit, and will slide second while moving around 50-60 with abit of a flick from the steering wheel though and a clutching. Third will do the at about 70-80 and on a nice sweeping bend. Just dont have the torque for a 3rd gear chirp in a straight line.
Will be great fun to drive when you build up the engine hey. The torque to weight will be awsome. Should enter in the local burnout comp.
datrat_dave
Posted: 2005/8/29 14:42  Updated: 2005/8/29 14:42
 Re: Dazza
That looks really good Dazza!! Got a clean line and finish to it, nice one.
Freak what mods to your engine have you done? I mean internal wise...?
I reckon that would be in the history books, a Datto in a burnout comp
Freak
Posted: 2005/8/30 11:34  Updated: 2005/8/30 11:34
 Re: Dazza
My engine is pretty basic really. Just an a14 with flat top pistons, the high compression oval port head(Gx lookalike), mild head work(just a clean up and the chamber layed back to flow more towards the spark plug), a mild 25/65 cam with .400thou total lift. Makes best power at 6500rpm and pulls through to 6800rpm before power begins to drop of. Then on the outside are the twin SU's, electronic ignition and 4-2-1 extractors.
Dazza what are the plans for the L20b? Are you going to make it rev abit or keep it real grunty down low. I bet with carbs, cam, exractors and compression it would be great fun to drive. You could still have a real streety cam and make good power.
dattodevil
Posted: 2005/8/30 11:51  Updated: 2005/8/30 11:51
 Re: Dazza
well done on getting those plates, I'd be grinning ear to ear, if I got them The ute looks real good, you must be pretty pleased with yourself
NIS15L
Posted: 2005/8/31 1:21  Updated: 2005/8/31 1:21
 Re: Dazza
looks good dazza.
dazzasute
Posted: 2005/9/9 11:21  Updated: 2005/9/9 11:21
 Re: Dazza
more pics:
