Main : Mechanical : Engine Stroker Piston
[<   Previous  2479  2480  2481  2482  2483  2484  2485  Next   >]
Stroker Piston
Stroker PistonPopular
Submitterrally1200More Photos from rally1200   Last Update2005/10/2 15:57    Tell a friendTell a friend
Hits3288  Comments0    0.00 (0 votes)0.00 (0 votes)
This is the Mitsubishi piston i am using in my A12 stroker setup. stock it is a 75.5mm but comes in std/0.5mm/1mm oversize it has a 3.2 cc dish but i have had them machined down .015" to make them flat tops and then have cut in valve pockets. they have 18mm pins and the top ring is also 6.5 mm down the skirt allowing for a exhaust valve pocket to be cut into the block.(for 33mm exhaust valve clearance)
