Main : Mechanical : Drive Train 180B master and slave clutch cylinder - for 63a box
[<   Previous  641  642  643  644  645  646  647  Next   >]
180B master and slave clutch cylinder - for 63a boxPopular
SubmitterevilsimMore Photos from evilsim   Last Update2005/11/12 2:51    Tell a friendTell a friend
Hits4734  Comments1    0.00 (0 votes)0.00 (0 votes)
some bits for the 63a gearbox into 1200 coupe mission. parts numbers from aussie supplier PBR. these cost no more that $60 all up. when asked which master cylinder you need, get the jap one (aussie one offered was girlock), for the slave cylinder you want the one with the bolt holes on either side of the piston bore.
waz1200
Posted: 2008/4/30 14:22  Updated: 2008/4/30 14:22
 Re: 180B master and slave clutch cylinder - for 63a box
wat slave do i use if im runnin a 180b master on a ca18det box??
