Main : Mechanical : Engine A15 block
[<   Previous  2439  2440  2441  2442  2443  2444  2445  Next   >]
A15 block
A15 blockPopular
SubmitterptomliMore Photos from ptomli   Last Update2005/12/14 11:49    Tell a friendTell a friend
Hits4170  Comments3    0.00 (0 votes)0.00 (0 votes)
Blown head gasket got me to take the head off. Thoughts?
Dodgeman
Posted: 2005/12/14 13:51  Updated: 2005/12/14 13:51
 Re: A15 block
If the reflections on the walls of cylinders 2 & 3 are anything to go by, i'd say you have glazed bores & an oil controll problem.
Clean all the gasket material from the deck & check it with a straight edge. If it is outside specs, then you can run a glaze breaker through the bores when you are having the block decked.
ptomli
Posted: 2005/12/14 14:36  Updated: 2005/12/14 14:36
 Re: A15 block
I was hoping to avoid taking the block out
Most of the gasket material is gone now, just little bits left to remove. When that's done I'll pray it's still flat. The oil control problem may have been due to the previous owner installing 65 idle jets into the 40DCOEs? Maybe
Found two blocked water galleries in the existing gasket, which I expect was causing some issues too. Pushing on through, not been too bad so far, but I've yet to get it back assembled. Nissan wouldn't sell me the head bolts till I took in the old ones, they weren't sure the A15 uses the same parts as the A14 stock they have. So another trip on the scooter later.
Kegs: I haven't got any more really. It's a fairly new car for me and each time I've gone to the perfect location carpark at the beach, some dratted film crew have beaten me to it. I'll get some done shortly and post them up, assuming I manage to get the thing running again this year!
hotrod88
Posted: 2005/12/16 3:46  Updated: 2005/12/16 3:46
 Re: A15 block
I have to agree with them both . looks like multiple probs. the gasket loks as if she blew betwwen 2 & 3 , and also the cylenders do look vey glased . you can see the pistons in the cyl. walls like mirrors.How rich are you runnin the fuel ? timming?
kegs
Posted: 2005/12/14 11:56  Updated: 2005/12/14 11:56
 Re: A15 block
blown between liddle two cylinders???
u reckon u could show me/us some pics of your clubman, looked mighty tasty in the small pic of it ....
