Main : Mechanical : Engine a12t side
[<   Previous  2456  2457  2458  2459  2460  2461  2462  Next   >]
a12t side
a12t sidePopular
Submitterchris1200tMore Photos from chris1200t   Last Update2005/12/4 8:00    Tell a friendTell a friend
Hits3481  Comments5    0.00 (0 votes)0.00 (0 votes)
Showing the carb box and the exhust manafuld and inlet
Lotto
Posted: 2006/9/22 20:12  Updated: 2006/9/22 20:12
 Re: a12t side
lindas soldaduras.......lol....nao havia mais tubos?
chris1200t
Posted: 2005/12/4 9:44  Updated: 2005/12/4 9:44
 Re: a12t side
yeh 1200rallycar its a blowthrough setup. the reason i didnt want to make a sucka is that iv allready done one and had it running all good and then one day i decided hey why not have a crack at a blowthrough setup. so as you can see i boxed a hitachi carby with a solid flote and am running a 135 in the primary jet and a drilled in the secondary. Also im using a IHI rhb5 turbo.
To explain it all the 2 pipes that come out if the inlets 1,2 and 3,4 connect up to two other pipes that come out of the bottem of the carby box and you can see where the turbo connects to the box. The internals are pretty much stock except a decomped head. I still need a electric fuel pump, regulator and to retard the timing.
120fly
Posted: 2005/12/4 11:49  Updated: 2005/12/4 11:49
 Re: a12t side
I was waiting for the pictures ,wasnt shure if you had given up ,good to see it all bolted up and on the way ,May i ask why you went blow through ..Could you post a pick of inside th box for a peep ..
Did it take much work to move the turbo from where i had it .
Oh yeah chris if your going to weld the manifold more bolt it up to a spare head this will help the plate from warping .theres also enough plate there to machine it flate for a good seal to the head keep up the work.......
matbighat
Posted: 2005/12/11 4:30  Updated: 2005/12/11 4:30
 Re: a12t side
Well, no pretty points, but sure hope it runs hard for ya
1200rallycar
Posted: 2005/12/4 8:31  Updated: 2005/12/4 8:31
 Re: a12t side
looks awesome.... but i have to ask, why when you've gone to the effort to fabricate everything, would you go for a suck through setup?
if i remember rightly you are in melbourne, what are are you in, im in bayswater i wouldnt mind having a look and chat with you (send me a PM if you like)
edit: it's not suck through is it? but youve still remote mounted the carbie, why? can you explain more about the setup please
kegs
Posted: 2005/12/4 8:47  Updated: 2005/12/4 8:47
 Re: a12t side
are all those manifolds mild steel? can you please explain the setup i cant make out whats going where ..... is that a water injection line on the airbox looks like the same as mine....
