Main : Members : ang94541 Milkshake
[<   Previous  21  22  23  24  25  26  27  Next   >]
Milkshake
MilkshakePopular
Submitterang94541More Photos from ang94541   Last Update2006/5/5 19:41    Tell a friendTell a friend
Hits2183  Comments4    0.00 (0 votes)0.00 (0 votes)
Darn.  I hope it's just the head gasket.
Dodgeman
Posted: 2006/5/6 8:41  Updated: 2006/5/6 8:41
 Re: Milkshake
What is that oil filler cap from? It doesn't look like any stock A series cap that I have seen lately. It looks, sort of,.... billet
ang94541
Posted: 2006/5/6 8:50  Updated: 2006/5/6 8:50
 Re: Milkshake
I made it out of two pieces of scrap aluminum during my apprenticeship.
I had a hard time tapping the holes. So I went to the next size up
Dodgeman
Posted: 2006/5/6 8:53  Updated: 2006/5/6 8:53
 Re: Milkshake
Well done.
Posted: 2006/5/6 8:33  Updated: 2006/5/6 8:33
 Re: Milkshake
Most likely. To be double-sure, you can do a compression test and a cooling system pressure test. We worked on a Camry last year with milkshake like that and it turned out to be the water passage in the intake manifold. Got the engine torn 1/2 down (but the head was still on) when I decided to do the radiator pressure test a second time. The first time it was just air leak I could hear seemingly in the crankcase but the second time (after I got the manifolds off) I refilled the radiator, then I saw coolant coming out the intake ... whew, I was glad I didn't pull the head. All it took to fix was a $2 gasket.
Contrary to popular opinion, A-series rarely warp the heads. So even if the gasket is blown, a careful deck prep (scrape and clean) and straightedge check is usually all that's needed. Do be sure to have it milled flat if it's out spec, but that's not usually the case. They can take a moderate overheating and just blow the gasket.
