To the L series fans
From Cape Town South Africa
As you guys know I have a L20b in my datto, but we wanted more power and I started by getting all the parts for the head I got stuck when it came to the sub. I wanted to fit VG30 Piston but for that I needed a conrod of about 151mm to about 152mm. I found them at 1st I wanted to keep it a secret but thats not what the datto forum is about. So I got my hands on a set of Childs Albert 6inch alloy rod from a 327cui chevy and they will do the job with only minor mods. Rated at over a thousend hp with a V8 piston on them I cant see my datto ever breaking those. Hope this info helps as I have searched the net and this seems to be a first for this combo. Thanx
Posted on: 2010/2/18 12:18
Re: To the L series fans
From Townsville, Qld
I take it they're a little wide and need some machining?
Posted on: 2010/2/18 12:34
Little wide on the small end but narrow on the big end
Posted on: 2010/2/18 13:09
Racing started the day the 2nd car was built!
From Geelong, Vic
why a vg30 piston?
Posted on: 2010/2/18 22:39
Why not just use the L-series conrod? They can take 175 HP.
Posted on: 2010/2/18 23:44
Vg30 piston isnt as heavy and you get them in a hi comp over the counter. With using a vg piston I needed a longer rod L series rod is around 146mm and I need 152mm. In doing it this way the rod ratio is also a bit better than standard L 20 thus running hi rpm becomes a bit safer.
Posted on: 2010/2/19 7:38
i always throught shorter stroke and larger bore were better for high rpm, not long stroke large bore? better for mid ramge and low rpm.
Posted on: 2010/2/19 9:37
From Brisbane
don't L24's have longer rods?
Posted on: 2010/2/19 12:06
AWD the way to go
I didnt change anyting regarding stroke the piston sits and move the same lenth. As for L 24 I think thats the same lenth as L16
Posted on: 2010/2/19 14:45
