Smallest diameter tires available?
What are the smallest diameter tires available these days? I want a set lower than stock.
Posted on: 2007/5/30 5:02
Re: Smallest diameter tires available?
From California
try mini mania
Posted on: 2007/5/30 5:06
Quite a regular
From homeless
4300 RPM's on the freeway isn't good enough?
Posted on: 2007/5/30 5:14
From San Jose, California
Have you checked tirerack.com? I'm using sumitomo 175/50/13's which have a smaller profile than the stock 12's. They were $36 each. I'm told they are meant for mini coopers. I don't know how the diameter compares exactly, but the dimensions for these tires are listed at the tirerack site.
Posted on: 2007/5/30 5:35
-Daniel
From Christchurch NZ
I once ran a set a set of 145/70/12's. They looked silly, but It could climb hills in 4th gear. (With a very slogged out A12)
Posted on: 2007/5/30 6:48
Forced Induction!
175 50 r 13 is smallest 13 available i found in aus, found 165/55/r13 as well which is the one i want.
they are designed for minis and can get a 165/55r12 too.
found a pair of 195/45r13 on my travels as well but rip off wanted $295 per tyre!
picked up 2 165/55r13 for cost. so only $70 each. not bad.
Posted on: 2007/5/30 10:14
From south coast nsw
12*70*145 pizza cutters.Open in new window
Posted on: 2007/5/30 11:21
From Redmond, OR
I just took off a set of stock 12" wheels for a 1200. Don`t need them anymore, even have (3) matching hub caps. If anyone is in need let me know
Posted on: 2007/5/30 13:30
Here is my motto: I may be getting older but I refuse to grow up
From Toowoomba QLD
sundat1200 wrote:
I'm using sumitomo 175/50/13's which have a smaller profile than the stock 12's. I don't know how the diameter compares exactly
According to my calculations, in theory they should be about 45mm lower OD than standard.
Posted on: 2007/5/30 21:02
