removing front mount for cooling issues....
From brisbane
i am having heating trouble in my my cadet. it has a brand new 240sx twin core radiator and 10 inch and 8 inch thermos but still getting hot in traffic. so i was thinking about taking the front mount off and putting 2 more thermos in front of the radiator as well...... the motor is basically stock and just been rebuilt except for a 3 inch exhaust and i was wondering how much power i would lose by removing the front mount, and could i still upgrade the turbo without one?????
Posted on: 2009/1/14 23:27
A15 1200 ute, 77 mini -b16a honda vtec project
Re: removing front mount for cooling issues....
From campbelltown (sydney) australia
you shouldnt be having any troubles have u checked your cooling system are u sure it hasno blockages? mine has a thin sprinter core with twin thermos and it doesnt get hot enough....dont blame the front mount doubt it will be causing the problem.
Posted on: 2009/1/14 23:49
* caution, sunglasses must be worn to view my ca18det *
From perth airport
i ran the stock silvia rad with a fmic and no over heating probs ( ran the stock fan )
treat the cause not the problem
Posted on: 2009/1/15 0:30
perth airport parking
Datsun 1200 ute A14
From brisbane
so it sounds like the radiator should be big enough then.... maybe the guy before me removed the thermostst centre and the water is moving through too fast to get cooled. if i start it up cold i should see water flowing straight away yeah???????? instead of when the thermostat should at designated temp?????
Posted on: 2009/1/15 1:23
From Tamworth , NSW
the water shouldnt move until the thermotat opens when it reaches temp and lets water flow.
Posted on: 2009/1/15 1:28
From perth airport
removeing the thermostat will make it run colder
Datsun 1200 ute A14
From Christchurch
You might just need to bleed the cooling system, having an air lock can cause overheating issues
Posted on: 2009/1/15 1:31
From brisbane
but if its passing thriugh the radiator too quickly it won't have enought time to cool it sufficiently... maybe??????? thats what i heard.. ie. it will be in and out before it cools.
Posted on: 2009/1/15 1:32
From perth airport
thermostats are ment to keep the car at a even temp
by the water staying still is will sit in the rad for longer but is will allso stay in the engine longer too
you want flow but running a car with out a thermostat is bad coz a car is ment to run at a preset temp running it colder can be bad
once again treat the cause not the problem :)
Posted on: 2009/1/15 1:38
Datsun 1200 ute A14
From brisbane
thanks guys...... i'll look into it a bit more. thanks for your suggestions.
Posted on: 2009/1/15 1:46
