Browsing this Thread:
1 Anonymous Users
N14-15 Radiator swap - Done :-D |
Home away from home ![](http://datsun1200.com/uploads/rank49ca09456ba1d.gif)
From Mildura, VIC
Did the swap on one of the utes today, I got a brand new n14-15 2ltr Radiator dirt cheap, Used Hyundai excel top mounts & made some bottom mounts. - A couple of universal hoses & al sorted. Well worth the effort. - The A15 used to get quite hot, now after a nasty "test-thrashing" wouldn't get over 90deg. - just got to hunt down some OEM thermo's next. - Can any one here tell me if they are using anything different on their N14-15 set ups?
Tomorrow's job will be re fit the single side draught, strut brace & one of Mal's dizzys. ;)
Posted on: 2009/11/2 14:44
Re: N14-15 Radiator swap - Done :-D |
No life (a.k.a. DattoMaster) ![](http://datsun1200.com/uploads/rank49ca09456da4d.gif)
From northern 'burbs adelaide
thats not a bad setup ... i went the hyundai excel radiator. looks good though mate
Posted on: 2009/11/2 21:36
From Cape Town, South Africa
Looks like business, I'm busy building a VW Caddy Ute radiator into my ute.
Posted on: 2009/11/3 6:36
From South Africa, Bloemfontein
@racetech Please send me some pics. I thought about the same radiator as they are cheap but decided to let it go due to the inlet and outlet going to give me problems. What are you going to do with the inlet and outlets?
Posted on: 2009/11/3 7:57
1977 Datsun 1200GX
From NZ
I see the top hose is on the correct side for A series engine. What side is the lower hose?
Posted on: 2009/11/3 8:36
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box. Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
should be same as a series, im using n13 one and its all good for fittings
Posted on: 2009/11/3 8:58
From Mildura, VIC
N14 - 15 perfect height, width & inlets for A series.
Just mounts, easy as.
Posted on: 2009/11/3 13:29
the hyundai top fitting is closer to the middle and you can get away with using the standard hose for it ... im unsure about the lower hose because mine has a funny alternator setup and my hose has to wrap around the top of it
Posted on: 2009/11/3 22:56
From NZ
Quote: NHB006 wrote: Did the swap on one of the utes today, I got a brand new n14-15 2ltr Radiator
What Make/Model car is an N14-15?
Posted on: 2009/11/7 0:48
Just can't stay away ![](http://datsun1200.com/uploads/rank49ca09456b69e.gif)
From sydney
nissan pulsar
Posted on: 2009/11/7 4:24
