Help????? tunning Weber 40 DCOE on a14
Do any one out there know how to tune weber 40 DCOE carb's ??? I have two but are strugling to get them to work properly. They are also heavy on feul. Help PLEASE!!!
jacovdberg@lantic.net
Posted on: 2003/1/29 17:11
Re: Help????? tunning Weber 40 DCOE on a14
From Sydney
what size jets are you using (mains, pump, idle, air corrector) and emolsion tubes as well as auxillary venturi and main venturi. ?
Are you chasing power or economy ?
What RPM do you plan to drive the engine ?
Do you use a fuel regulator ?
Enough questions for starters.
Cheers
Posted on: 2003/1/29 23:26
I borrowed an excellent book from the library: Weber Carburetors Owners Workshop manual by Haynes UK. (Amazon.com link)
It has this in the back. The B210 specs should be a good starting point for a stock A14.
Conversion equipment jet setting
Datsun B110
Carb: 40 DCOE 2
No. Carbs: 1
Choke size: 27
Aux. venturi: 4-5
Main jet: 1-10
Emulsion tube: F7
Air corrector jet: 1-65
Idle jet: 0-50 F9
Accel. pump jet: 0-50
Accel. pump inlet valuve with ex. orifice: 0-50
Needle valve: 2-00
Datsun B210 & F10
Carb: 40 DCOE 2
No. Carbs: 1
Choke size: 33
Aux. venturi: 4-5
Main jet: 1-30
Emulsion tube: F11
Air corrector jet: 1-80
Idle jet: 0-50 F8
Accel. pump jet: 0-60
Accel. pump inlet valuve with ex. orifice: closed
Needle valve: 2-00
Datsun 510
Carb: 45 DCOE 13
No. Carbs: 1
Choke size: 33
Aux. venturi: 4-5
Main jet: 1-30
Emulsion tube: F16
Air corrector jet: 1-90
Idle jet: 0-50 F8
Accel. pump inlet valuve with ex. orifice: 0-55
Needle valve: 2-25
Datsun 510
Carb: 45 DCOE 12
No. Carbs: 2
Choke size: 32
Aux. venturi: 4-5
Main jet: 1-35
Emulsion tube: F15
Air corrector jet: 1-70
Idle jet: 0-55 F2
Accel. pump jet: 0-40
Needle valve: 2-00
Posted on: 2004/4/30 4:48
Quite a regular
From Sydney, Aussie
Before you get right into buying all the different jets, chokes etc you should check a few things out about the carby;s themselves.
Apparently a major problem with old 40mm DCOE webers is that unlike most of the 45mm webers 40s had the venturi's located with the aid of a groove in the wall of the carb. Factory venturies had long sleaves that extended to the start of the carb and were positively locked into place by the ram tubes/aircleaners.
Anyway the result of X amount of years of vibration whilst bolted to the side of the car means that the venturies may be sloppy inside the tunnels. fuel from the jets can leak past the venturie's and make the things nearly impossible to tune right.
Check out you carbs by taking off the air cleaners and first checking they have the factory fitted ventuires that rest against the ram tubes/aircleaners. If they don't you may want to make up sleves that hold them tightly against the chokes. Second check that the venturies don't wiggle around inside the carb tunnel. If any do you've probably found a good place to start thinking about doing some work.
What that work may be i don't know!
Never played with them before just relaying warnings i recieved from others and experience in actually "wiggling" a set of sloppy venturies in a pair of 40mm carbs.
Mabey some careful use of a quality gasket sealing agent around the venturies. Wanna be really careful you didn't get it into the fuel supply tunnel though other wise you'll ahve a new set of dramas. Mabey just a thin smear between the venturies and the chokes.
(45mm webers mostly/all seem to be located with grub screws locking them in place from the side)
check out this web site for excellent advice on basic tuning of webers:
http://members.aol.com/dvandrews/webers.htm
It's orientated at pinto's but it can be applied to 1400 - 1500s i reckon.
Posted on: 2004/4/30 6:04
From Invercargill, New Zealand
Great info - thanks!!
Posted on: 2004/4/30 6:09
Hi there.
I am also in the process of setting up a set of 40 DCOE's for my 1400. I found a baseline setting on the web. 30 or 32mm chokes. 125 mains 180 air corrector.F15 emulsions. 40f9 idle jets. I am aiming for 6000-6500rpm max power. I have a lightly ported head with a lightened and balanced flywheel and balanced crank. Any advice on that would be great.Thanks. Hey Jaco what manifold are you using, where did you get it and how much. You are from SA aswell?
Thanks
Pierre
Posted on: 2004/4/30 6:17
Quite a regular
From Sydney, Aussie
For those in sydney you might be interested to know that Carburettor service company on parramatta road Burwood have/had a matched pair of 40mm webers.
Good condition except for ONE of the venturies being a bit sloppy. They were the factory venturies that extend to the aircleaner/ramtubes in order to positively locate them against the chokes.
They wanted $600.
Posted on: 2004/4/30 6:46
From Sydney, Australia
The website mentioned above has since moved from AOL :
http://www.dvandrews.co.uk/
Posted on: 2012/12/29 4:19
