needed: m83 hitachi side draft needle jets.
From vancouver, wa. usa
Im running sss l16 su style hitachi side draft carbs on my a14, and need to aquire a set of m83 needles, or the proper needles for an a14, the wiki suggest m83
Posted on: 2014/7/5 10:28
72, 1200 coupe
77, 710 2 door sedan
Re: needed: m83 hitachi side draft needle jets.
From Sydney
From memory you should be able to use SU needles which interchange. If not , an option would be to drill out the hitachi jet in order to use SU needles.
Posted on: 2014/7/5 10:56
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Nissan part number 16554-H2316.
Posted on: 2014/7/5 20:39
I dont plan on drilling out anything to fit su needles.
Thanks david.
Posted on: 2014/7/5 21:16
72, 1200 coupe
So after waiting a week I called to see where my needles may be, and I was told they are no longer available and I would see a refund next week....
I need a set of needles. Asap.
Posted on: 2014/7/13 20:09
72, 1200 coupe
From La mesa ca
If you can not get M83 needles you could use M76. If you got the su off a 510 the needles could be M66. I have a sheet that lists all the datsun needles.
Posted on: 2014/7/16 14:34
Thank you, m76 adeed to my search list. Does your sheet show the profiles by any chance? Z therepay could make me a set if I had them. Wouod alao be interested in the m66 profile.
Posted on: 2014/7/16 17:27
72, 1200 coupe
From La mesa ca
Here is part of the data sheet for Datsun SU needles. The number next to the needle picture is .100 down from top.
jpg  SU needle sheet.JPG (41.95 KB)
17913_53c7ddc52dcb3.jpg 400X533 px
Posted on: 2014/7/17 15:32
Wow man, that is stellar. Verry helfull thank you. I will see about getting this added to the wiki.
Posted on: 2014/7/18 8:25
72, 1200 coupe
From Brisbane, Australia
This might be helpful down the track:
http://www.mintylamb.co.uk/suneedle/
Posted on: 2014/7/19 4:54
