« 1 ... 3 4 5 (6) 7 »
Re: States 1200 Coupe. (Oregon, US)
From Creswell, Oregon USA
Posted on: 2015/7/29 4:49
An idea doesn't work unless you do.
Instagram @MD_Machine
Parler @MDMachine
From Snohomish, WA USA
What do those cost?
Posted on: 2015/7/29 6:29
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
So far time is all it has cost me.
They take 4 hours to make per side.
Posted on: 2015/7/29 14:34
From Los Angeles,CA. USA
That valve cover is a work of art! Would you make another to sell me?
Posted on: 2015/8/11 1:00
That thing took forever on the mill. Also it was a nerve killer with how deep the milling had to go.
Posted on: 2015/8/11 3:45
Parler @MDMachine
Would you sell that set for $300?
Posted on: 2015/8/11 4:29
The Vents DD?
Posted on: 2015/8/11 4:59
Parler @MDMachine
I started working on my Intake for the car this week. I made the intake parts as bolt together items since I didn't have the capability to machine runners like this from a solid block. the mating surfaces have a .254mm groove on the face to hold small beads of RTV. Smother the surface with RTV and clamp with the bolts.
Today I pressure tested the results in the water tank. I tested up to 30psi seeing I wouldnt be running over 15psi from the super charger. No leaks from the seam.
Posted on: 2016/8/26 21:14
Parler @MDMachine
From Adelaide
They look nice, are you going for a twin TB setup?
Posted on: 2016/8/26 22:54
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
this kind works with Datsun 1200 throttle cable
Posted on: 2016/8/27 0:01
