E-16 crank in an A15?
From USA
Guys,
I've heard rumors that the E16 (88mm stroke) crankshaft can be modified to install into an A series block. The A15's crank has an 82mm stroke. My 3 mm over A15 currently displaces 1608 cc's. An E16 crank would give me 1725 cc's!
Does anyone have any experience or knowledge on how this is done or if it can even be done?
Posted on: 2007/12/3 17:32
Re: E-16 crank in an A15?
There is a speedway competitor on this forum and also a crank machinist that uses the e13 series crank into a12 and also uses the ohc e15 head to make it an OHC A series.
Now this would be possible to do it the other way round.
The other thing is that the e series crank has the 40mm rod journals which are like bike engines and offer that little bit more all up.
Another method would be to keep your a15 crank use the e15 rods and offset and resize the rod journals to increase your stroke.
Posted on: 2007/12/4 4:56
That will not increase the stroke
Posted on: 2007/12/4 8:12
Yes it will.
Posted on: 2007/12/4 8:22
Love your Datsun.
Treat it well.
From Darwin NT
no it will not because the crank is still pushing the piston the same as it would with the standard rods just the piston will reach bdc higher then with the standard rods but the piston will still travell the same distance
Posted on: 2007/12/4 8:27
current project 4x4 patrol...
Dodgeman wrote:
Yes it will.
If he had said "offset and resize the crankpin" it would increase stroke, changing the rod journals would only change the stroke / rod ratio
Posted on: 2007/12/4 8:43
I've taken 'rod journal' & 'crankpin' to be one & the same thing. At least, that's what they taught us in tech when we were doing engine reconditioning.
Fitting a rod of different length would change the rod length to stroke ratio as would stroking the engine & keeping the same rod.
Posted on: 2007/12/4 9:12
Love your Datsun.
Treat it well.
Think you're getting confused between "big end" & "main" journals (crankshaft) and "rod" journals (conrods)
Posted on: 2007/12/4 9:51
I agree with dodgeman, rods don't have journals as such, to my understanding a journal is a surface that a plain bearing runs on, not a surface that the shell backs up against and has no relative movement against.
Posted on: 2007/12/4 10:40
Dodgeman wrote:
Yes it will.
Its easy to get it all confused - big end, little ends, rod and main journals, crankpins and crabsticks
MLS Im glad you are not working on my crank!?
not a great deal but the 2 minute illustration I made on my new
Posted on: 2007/12/4 10:56
