« 1 (2)
Re: Installing Distributer on TDC
hah dd,
I see distributor and help and that's what I give everyone. Shameless self plug :P
Posted on: 2009/12/23 7:37
From Sri Lanka
HI DD
According to this page
http://datsun1200.com/modules/mediawi ... le=Installing_Distributor
1971-1972 and 1973-1976 has different timing marks isn't it ? mine is 1974 model what should i select 0 or 5 as TDC ? I have selected 5 as TDC now
Thanks
Regards
sumith
Posted on: 2009/12/29 6:11
the 0 mark is TDC. The 5 mark is 5 degrees before TDC
Posted on: 2009/12/29 7:16
From Sri Lanka
Hi Guys
i was going through this link
http://datsun1200.com/modules/mediawi ... php?title=Ignition_Timing
Feel that the information is not sufficient enough for me regarding Advace and Retard as i am not a technical as much, can any one tell me when installing distributor on TDC which mark should i select from Advance and Retard is it middle of both ? then configure it later as per the page or what ?
thanks
Regards
sumith
Posted on: 2009/12/30 6:25
When "installing distributor on TDC", use the 0 mark, which is TDC.
However, that is not the timing procedure. Set the spark timing against the 5 degree BTDC mark. Datsun typically specified 5 or 7 degrees timing.
The article can be expanded, click Edit and type in more.
Posted on: 2009/12/30 7:41
« 1 (2)
