help needed! engine coughs uncontrollably
From sydney
help needed! i have put a new engine in my car, its a 1400 that i bought off a guy that apparently had it in his ute with a turbo, i'm trying to get it running and tuned properly, the timing seems to be right but it does'nt idel and when i push the the accelerater it coughs what looks like a little flame out of the carby? im stumped! can someone pleas help me?
Posted on: 2010/3/4 7:59
Re: help needed! engine coughs uncontrollably
From Perth WA AUS
Sounds like timing to me, but I'm not too good with tuning motors.
Posted on: 2010/3/4 8:40
Datsun 1200 2Dr sedan.
From Coondle, WA Australia
I would def check the timing. Has the dizzy been out of the engine? If so, has it been set correctly. one tooth out is enough to throw out your tuning.
If it is an ex turbo motor, maybe the dizzy has been fixed or recurved and now is outa wack for a NA engine.
Posted on: 2010/3/4 9:04
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
From sydney
it come with a electronic dissy and i put it in i did the usual thing, put it on tdc and the rotor was at number 1 etc. i can rev the engine a little bit but it coughs under load when i rev it, i have put a timing light on it and the timing is around about right but i can't get the car to run long enough to get it spot on. could it be anything else? just trying to eliminate the possible problems.
Edit: not sure about the dissy, he never had it running on the turbo motor he reakons, he had a normal points dissy
Posted on: 2010/3/4 9:07
From sydney
any other ideas?
Posted on: 2010/3/4 10:15
From Bendigo, Victoria
Leads on the correct plugs? I stuffed up on 2 and 3 once - took me a week to work it out.
Posted on: 2010/3/4 10:28
From sydney
1-3-4-2? thats what i've got
Posted on: 2010/3/4 10:31
From Sri Lanka
Posted on: 2010/3/4 10:58
From Albany, Perth Australia
you may have put it on the wrong stroke....so it might be 180 degs out
Posted on: 2010/3/6 1:36
1200 Smerf Mobile
Coughing out the carby is someties too advanced timing. Try retarding the timing, turn the distributor opposite the direction the vacuum advance is pointing.
Or an intake valve could be stuck open. Pull the rocker cover and adjust the valves. If one is very loose, it may be stuck. If one is tight, it probably is not closing all the way.
Posted on: 2010/3/6 1:57
