accelerator pump lever assembly
From Malaysia
i have a stock carb,
i found that the accelerator pump lever have two hole, my question is, is there any performance/FC different between using those two holes? i understand that using the hole that is nearer to the fulcrum makes the accelerator pump travel further. why there are two holes?
i know my english is bad, im talking about part number 3.
Posted on: 2010/8/9 13:42
Re: accelerator pump lever assembly
This is common in carburetor design.
The two holes are so it fits a variety of engines. Typically one hole is used for one model and the other hole when used on another model.
The instructions should indicate which hole to use.
Posted on: 2010/8/9 17:15
From Malaysia
is it the mixture is richer when using the hole that is closer to the fulcrum? (during sudden throttle opening)
Posted on: 2010/8/9 17:33
From Portland OR. USA
Yes.
Posted on: 2010/8/9 20:53
From sydney australia
I believe the 2 holes are to give different speeds that the fuel is added to the airstream. The further out the hole, the slower the fuel is sprayed in. The inner hole is at the same length as the single hole arm, so there is no advantage using one of these arms. You basically get the same amount of fuel, just not as quickly if you use the outer hole.
Posted on: 2010/8/11 11:11
From Sydney
pump cct duration.
Posted on: 2010/8/11 11:53
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
From Malaysia
is it? because i think if im using the outer hole, the accelerator pump travel is reduced.
Posted on: 2010/8/11 16:34
