« 1 2 (3) 4 »
Re: WA Rego with an a15 ,engineer cert ??
From mandurah
Cheers neil !
so with an upgrade on the brakes its doable to get my ute regoed with my a15
Its got new cylinders and shoe linings in the rear with skimmed drums ,and late model 120y struts up front with new pads and rotors
Btw ,what pits do you go to ?
Posted on: 2011/7/4 16:05
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Perth
Who-ever will pass it
Don't you country bumpkins have a local workshop that does it
Posted on: 2011/7/5 0:52
From Freo
Ben just took the KB10 over..
Engineer required,
A15,
Twin Carbs,
Exhaust
Disk Brakes
5 Speed....
thats the short list..
Posted on: 2011/7/5 1:13
A15 PSI Project Motor
'72 CB750k,
From mandurah
Haha country bumkins ,im in man du raaah not muntagin haha
Yea mandurah bus charters do it
Well mine might be easyer than bens being a 1200 and the engine being a bolt in ,but still the carbs are a problem
Who should I get to insure this thing ?
Posted on: 2011/7/5 3:22
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Perth
Why are the carbs a problem ?
If it can pass a 4 gas test it meets emissions for the year
How about you ask someone at the pits.... or at MBC
Or just front up
As for insurance... bend over and grab your ankles
Posted on: 2011/7/5 11:49
From Perth WA AUS
With upgraded brakes you will need it engineered for sure ( correct me if I'm wrong please).
Posted on: 2011/7/5 11:54
Datsun 1200 2Dr sedan.
From mandurah
Thats a good point but then im running a set up that is bolt on ,no fab work so I might not need a cert for that ,not sure though
Well it looks like ill have to get it engineer to go over it and tell me what the go is ,was talkin to mike tonight about maybe putting an air box on it ,just so I can get rego with my carbys
Posted on: 2011/7/5 12:00
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From Albany, Perth Australia
the rules have either changed or are changing that all old cars going to be licensed must meet todays standard in emissions and not the year of manufacture so as i said before ring up the tech section at welshpool and find out the facts. they will also give you a number of an engineer that can look at it too, but will most probably be sam as jack apgar isnt doing it anymore after his stroke
Posted on: 2011/7/5 12:01
1200 Smerf Mobile
From Perth WA AUS
Airbox is a very good start.
Posted on: 2011/7/5 12:05
From Perth
When I got my ute engineered the process was you fill out the modification application with what you want to do they will send you back a letter saying that you can do it and what standards it has to meet with a list of engineers yours shouldn't be a problem with A15 with twins. You are better of getting the Tech section to tell you what testing it has to pass.My engineer wanted mine to do emissions test we argued for a week or so rang tech section and asked about it and said the test is not listed on approval letter you dont have to do it. Which was good I didn't want to spend up 2 grand at Kosteci's. With engineers cert guys at pits didn't bother driving it just had to wait 3 hours to write report
This was in 2008 the engineer was $440
Posted on: 2011/7/5 12:25
« 1 2 (3) 4 »
