« 1 (2)
Re: first problem in vic engineering laws
From Canberra
Before I got the conversion done on my ute I rang the ACT rego place & they said that the heaviest vehicle in the rnag was the wagon at 720kg. So 720x2.5 = 1800cc so it's a tight squeeze.
Posted on: 2011/7/15 13:51
YLD.18L
Your starting to scare me now Tommo...cos I don't reckon I'm gonna get my car finished in the 6 months Sanjay has alloted....hopfully this weight deal doesn't impact commercial vehicles (utes)!
Anyway keep us posted with any developments.
Posted on: 2011/7/15 14:48
The new rules are easier in one area...
eg. a10 to a12 dont require a e-cert? As it supposedly states that power or capacity? must not increase over 20% from original motor. Old one state no more than 15%
You guys with 1200 are lucky us 1000 people...
B10 - 650kg
1625cc turbo
1950cc NA
KB10 675kg
1687cc turbo
2025cc NA
Posted on: 2011/7/15 15:59
From Goulburn NSW
Hi guys so are we able to still put the ca18 into the ute in nsw and how does it work if the motor is worked
Posted on: 2011/7/16 3:29
From Melbourne, Australia
In simple terms, yes you can and it depends on what "working" you're talking about. Internally, they are never going to get you to pull the engine apart to see what internal mods you have. There's not a lot of things you can do to a non turbo that will attract the attention of the engineer.
Posted on: 2011/7/16 3:43
Current Fleet-
1996 R33 GT-R Skyline
1996 Falcon XH XR6 Ute
1977 Datsun 1200 Ute A14 (Fergus)
2012 VW Passat TDI Wagon
From Goulburn NSW
hi shoota i actually meant ca18det
Posted on: 2011/7/16 5:13
Ok, in that case, don't go a big arse top mount exhaust manifold, stick to standard intake manifold and you will have to run standard computer till after engineering too.
Posted on: 2011/7/16 7:05
Current Fleet-
Im confused reading their new rules again.
Can anyone chip in to the layman here?
so what are my restrictions with or without boost?
I thought that anything is allowable now as I cant
see any calculations anymore just Engineer approval.
Jason wont he budge and pretend its an auto model?
Posted on: 2011/9/3 7:35
Edited by D on 2011/9/3 12:13:59
$hit tommo what a bugger, or anyone with a project on the go. Its got me stuffed how there can be so many different thoughts from the guys signing off on the certificates. You will get through it
Posted on: 2011/9/3 10:11
For a cheap car these datos can get super expensive....!
All the bits for my ute have been acquired, I only need time and a panel beater/painter! Anyone able to help
« 1 (2)
