A15 power or lack of power
From RSA
just got my car back from dyno and i'm a bit p%^&* off.The A15 got 91.6kw and 156nm torque.But if this is wrong or correct i would not know as the diff turned cos i forgot to weld the blocks it is laying in or rather thought the u- bolts would hold.anyway was hoping to go higher.a14 with a15 crank,gassed& flowed head,l/fly-wheel,all balanced,custom intake,zx600 t/bodies,zx1000 inj,alfa junior lsd,gotech ecu,plus bigger valves,stronger springs as supplied by engine builder[valves]
Posted on: 2011/10/24 8:28
Re: A15 power or lack of power
That's pretty healthy at the wheels. I wouldn't be dissapointed with that. 91 kw Is strong for na
Posted on: 2011/10/24 9:02
From Wagga Wagga
Wow! That's 122HP that pretty darn good at the wheels! I'm flat out pushing 90HP....
Posted on: 2011/10/24 9:32
1980 Datsun 1200 Ute (WIP)
A15 Engine
5 Speed Sunny
H165 Diff
alfa junior lsd diff choice! 120+hp atw aint shabby at all!!!!
Picks pls!!!
Posted on: 2011/10/24 9:42
From RSA
D I am no good with pics but i'll get s/one to give me a hand later. This is a car that was going to the road but i did not like the spray job and the bonnet vent so decided for the track.runs a bit hot [100]but i'm confused cos dyno chappie told me to get corsa sensor but i read a few articles on here--other members had the same prob.Still want to get a sleeve kit from otomoto and things should be ok.back to the heat gauge--one for engine in normal position & 1 in rear of head[heater ent] for ecu.So got to sort some things. Will make a plan with pics
Posted on: 2011/10/24 11:40
Try photobucket its easy and permanent album for yourself
to look back on and share with others
Posted on: 2011/10/24 12:00
From Snohomish, WA USA
That's good HP for a A15. I wish I would have known what my built A15 put out before I added a supercharger and nitrous. Ended up smoking the motor but it did last a couple of hard years. Im guessing I pumped 200hp out of it with all the crap I added.
Posted on: 2011/10/24 17:53
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Posted on: 2011/10/25 2:44
From NSW, Australia
I've just had a safe tune done last week on my A14 turbo running 8psi and it made 102Hp at the wheels. I was dissapointed till i drove it home. the power to weight is on our favour bigtime.
I will have it re-tuned after a few adjustments i need to do, including more boost with a dual stage boost controller and a few other upgrades.
Keep in mind its a small motor, Drive a std datsun then get in yours. I built mine to cruise and have some fun, if i was after quater mile machine or big Hp i would build a 2L turbo.
Keep us posted
Posted on: 2011/10/26 4:33
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
From RSA
thanks
thanks Bigd --suppose i was expecting to much --maybe it's this 1400 uno turbo i have,man this thing f%%$^ off.don't need no encouragement and it's stock standard.Engine is great but the body is a rust experiment in progress --got it since '92 still going.Another thing is the builder said he is not gonna go heavy on the motor cos then i can come back & go turbo.Bigd i would like to ask you about the heat.the motor is running at 100[temp].Now there are 2 heat sensors, 1 for the motor &1 for ecu.How can i get this down[temp]work temp[71-88]? heard about hole in t/stat-bigger etc.any idea
Posted on: 2011/10/26 7:54
