What pound springs on rear coilovers in 1200 sedan
From Narellan,Sydney
Has any body got a figure for rear spring rates for a sedan? I'm running a 13b turbo and 4 link rear end.any1 have any ideas On what pound springs? Thanks
Posted on: 2013/1/25 22:53
Re: What pound springs on rear coilovers in 1200 sedan
From St. Louis, MO USA
Datrotor, I have used 175 lb, 200 lb and 250 lb springs in the rear of 1200 race cars. With these spring rates the car was fairly soft.
What are your front spring rates? Peter
Posted on: 2013/1/26 0:02
Mines a street car.only a weekend cruiser but.im pretty sure the fronts are 250lb
Posted on: 2013/1/26 0:43
All stainless steel-mild steel Sheetmetal and tube work
All types of welding
Custom metal polishing
BSA custom fabrication 0415 904 474
The stock rear spring ratio is
EDIT: corrected:
* Sedan,Coupe: 109 lb/in
* Van: 137 lb/in
* Truck 4-leaf:149 lb/in
* Truck 5-leaf:203 lb/in
Posted on: 2013/1/26 1:14
Edited by ddgonzal on 2013/3/28 8:12:51
From Sydney, Australia
350pd leafs for 2-3 inch lowered is good for a 1200 with a bit of power.
Depending on the angle the springs are mounted you may need more than that for a 1200 with some grunt.
Posted on: 2013/1/26 7:36
Anyone got anymore suggestions? I have 250 pound fronts.rears are vertical.im thinking 250 pound rear too.will this be to soft you think?
Posted on: 2013/3/28 6:02
From Brisbane, Australia
250lb is 4.5kg. Too stiff imo. But it depends alot on what the wheel rate works out to be, which depends on how far inboard your lower coilover mount is. Assuming its in the standard location for the shock, I say that's far too stiff for a street car.
I don't know where dattodude got that figure from, but it's either a typo or a plain old mistake. Kings lowered leaf springs for 1200 are 150lb/in.
What's soft for a race car on slicks or semis can be hard for a street car on normal tyres. The more grip you have the stiffer the spring rates you need.
Unless you have 50:50 weight distribution, I wouldn't be going for the same spring rates front and rear if the rear is anything like 1:1 motion ratio - it will make it very tail happy!
This page from Pitroad shows the spring rates they use on the heavier B310 4 link rear end. http://translate.google.com.au/translate?sl=auto&tl=en&prev=_t&hl=en&ie=UTF-8&eotf=1&u=http://www.pitroad-ts.com/A-parts-2/bushing/spring-rr310.htm&act=url
The Pitroad spring 3kg is what they use in their TS Cup race car on 9" wide rear slicks. That's 165lb/in. They cut 2 coils out of it for the race car which will make it slightly higher rate - say about 175lb/in at a rough guess.
The normal spring 1.7kg is the stock spring rate, which is 95lb.
NISMO 2.26kg is 125lb.
The best bet for a custom setup is to go to a race type suspension specialist, get the car scaled and work out the natural frequency as a starting point. Anything else is just taking a shot in the dark. But if that's the approach you want to take, I'd start around 150-175lb assuming the spring location is pretty much where the leaf spring was.
Posted on: 2013/3/28 9:36
Thanks for that L18 my shock mount are in further then standed leafs as I have 17x10 wheels in the rear.the shocks work out about 650mm centre to centre of each shock.standed leafs would be more like 900mm centre to centre.so they are in a bit more.would this mean a little more then you just predicted?
Posted on: 2013/3/28 9:46
yes, that will need higher spring rates to get the same effective rate at the wheel. you'll need to work out, or measure, the motion ratios as well.
Posted on: 2013/3/28 10:03
Yeah I'd say around the 175 give or take, the best way is to measure the weight of the car front and rear and your mate should be able to sort that the he should know the calculation to find the right rate spring, there is a lot of info on Ozdat about this!
You can google the conversion for weight to spring rate as well!
Posted on: 2013/3/28 10:33
Car free
