« 1 (2) 3 4 5 »
Re: Bobbys 1200 sedan build
From MOOROODUC. Victoria
Changing colour is a bit of a pain .... EVERYTHING needs to be painted otherwise it doesn't look right
Posted on: 2013/8/1 22:23
From Armidale N.S.W
Trufit are great ive got 3 different 1200 carpets off them and an lj torana one with no complaints. Just spend a little more and get the good waterproof one.
Posted on: 2013/8/2 6:04
73 1200 wagon SOLD
Update. Going full respray all glass and motor coming out this week. Any advice on preping for the ca18det before paint?
Eg cut out battery tray and intercooler space. Before paint.
Cheers
Posted on: 2013/10/3 7:50
From an engine bay perspective you almost need to test fit everything before you get it sprayed to avoid damaging the paint.
You've listed some of the main things by from my experience the following should be considered:
- cut out for inter cooler
- removal of battery tray
- hole in firewall for clutch master
- mounting holes for radiator
- several small holes for mounting relays
- I relocated washer bottle so had to drill a hole for the plastic tubing
- hole through firewall for new engine harness (quite a big one if you use stock S13 loom)
- if your getting this engineered and using a front mount inter cooler the engineer will want you to use a factory air filter box so this will need mounting points.
That's all I can think of at the moment.
Good luck 😀
Posted on: 2013/10/3 8:19
Also radiator support needs to be supported if cutting depending on engineer, plus like above I'd test fit all before paint as there is a fair bit involved!
Posted on: 2013/10/3 8:55
Car free
update!
removed motor and gearbox all glass out.
getting ready for paint and waiting to see if I can go ahead with engineering for a ca. Also thinking 12a rotary too.
Posted on: 2013/10/8 10:30
From Western Australia
Go the rotor!!
Posted on: 2013/10/9 0:50
1974 1200 Ute - Build
Either way you will need an engineering certificate
who have you, or are you going to, contact ?
Sanjay did mine
Posted on: 2013/10/9 5:31
From Brisbane
Dont go 12a ffs waste of time. You can make more power from the stock engine. If your not aiming for over 200kw stay with the stock motor. Hope you have the money and time to finish this project. Good luck : )
Posted on: 2013/10/9 5:46
Have to speak to a engineer first up.
so much to do from here
Posted on: 2013/10/9 8:12
« 1 (2) 3 4 5 »
