rain = wet feet whats the solution?
From Melbourne Vic
it rained down here in melbourne last night, and boy did it rain!!! anyway it reminded me of how i have a small but very annoying leak which results in driver and passenger footwells ending up wet. what have other people done to fix this, as it is rusting in the little vents near the wipers but i can't get right down there? anyone else have this problem?
Posted on: 2005/2/3 6:00
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
Re: rain = wet feet whats the solution?
From Perth, Australia
the dash is really simple to pull out, just pull it out and fix it from the inside. or move to Perth, 38 degrees today. no rain in sight.
Posted on: 2005/2/3 6:04
Datto 1200 ute undergoing rebuild... one day it will be finished. i hope. *FINISHED*
From Springwood NSW, Formerly Tas.
simple cut out the floor so it dosnt fill up with rain
and yes it happens to me aswell its all rusted up under the dash on the passenger side.
Posted on: 2005/2/3 6:11
From Melbourne Vic
cool, dash is out atm, i was hoping i could fix it from the inside. nice. so what product should i use to seal it? it pissed down all night, but was sunny all day and is supposed to rain over the weekend and supposedly it snowed in the mountains ... gotta love melbourne. any other leak fix experience?
make sure you treat the rust first. then the best way would be to weld in a new section and seal the edges with a product similar to bostik. thats how i would do it
Posted on: 2005/2/3 7:23
From WA
if you take off your cowling panel (the vents just before your windscreen) and peer inside you might see some rust there.
if there is any (and it's a common problem thanks to leaves, sand, dead mice...) chances are that's where it leaks. easy fix with the dash out though :o)
Posted on: 2005/2/3 7:59
From Melbourne Vic
cowlick panels are out, and i cleaned a heap of leaves out but there is minimal rust there. its just on the inside where the panels meet. hopefully an easy fix, i'm just wanting to do it properly the first time!
Posted on: 2005/2/3 8:08
From Melbourne, Australia
i had similar problem, when i changed the front quarters i found there were holes behind them up in the top corner, since i cleaned up and plugged them ive never had a problem with it again
Posted on: 2005/2/3 8:16
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Melbourne Vic
well i took off the front gurads expecting to see gaping rust holes, and there was nothing! yay! so i went up to bummings and said to the guy "you remember that add in the eighties where the guy got that metal strainer for peas and sprayed it with that grey stuff and it sealed..." and he went and got me a can of this stop leaks spray. sick. so i'm gonna clean up the inside of the upper bit where the dash goes and spray the bejesus out of it. thanks for the help fellas
Posted on: 2005/2/4 23:43
also check where the wipers bit sticks through to the outside....had a small leaking problem there and fixed it with a quick squirt of silastic
Posted on: 2005/2/5 7:21
