Clutch has been installed.What is correct play on clutch cable?
From South Africa, Bloemfontein
Hi all
Good news.
I was really mad when I saw what was going on on the inside.
The previous mechanic never replaced the pressure plate.
Gearbox seals was never replaced.
Crank seal was also not replaced.
Too much grease was smeared on the main shaft and it splattered onto the clutchplate which made it chatter.
All seals was replaced and I also drained diff and gearbox oil.
Oh and the flywheel was cut like the nevada mountains.
This was also redone.
This time I supervised everything.
My question now is the following:
The clutchcable we setup according to the manual on this site.
at gearbox 4-5mm play and at the pedal 11-15mm play.
When I press the clutch pedal it stops about 2cm from the floor.
Can I just change the play in the clutch cable so that it touches the floor when pressed?
I feel something will get damaged if someone else drives the car and does not know about this and tries to press it hard to the floor.
Thanks
Posted on: 2004/4/15 12:35
1977 Datsun 1200GX
Re: Clutch has been installed.What is correct play on clutch cable?
From Melbourne, Australia
hmm, while were on the subject ive never sucsefully adjusted my clutch so that it doesnt engage near the top of the pedal travel, never, not even with new clutches, i hate em too!!!
then i get in others cars and stall em cause i let the clutch out too fast near the floor thinking itll be like mine
Posted on: 2004/4/15 14:20
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Still awaiting for some more replies.
Thanks for your reply 1200rallycar.
Posted on: 2004/4/16 11:54
1977 Datsun 1200GX
From Christchurch NZ
Yeah, back it off till it touches the floor if you like. Or dont let anyone else drive your car . Or both!
Posted on: 2004/4/17 23:51
Forced Induction!
