Clutch has been installed.What is correct play on clutch cable?
From South Africa, Bloemfontein
Hi all
Good news.
I was really mad when I saw what was going on on the inside.
The previous mechanic never replaced the pressure plate.
Gearbox seals was never replaced.
Crank seal was also not replaced.
Too much grease was smeared on the main shaft and it splattered onto the clutchplate which made it chatter.
All seals was replaced and I also drained diff and gearbox oil.
Oh and the flywheel was cut like the nevada mountains.
This was also redone.
This time I supervised everything.
My question now is the following:
The clutchcable we setup according to the manual on this site.
at gearbox 4-5mm play and at the pedal 11-15mm play.
When I press the clutch pedal it stops about 2cm from the floor.
Can I just change the play in the clutch cable so that it touches the floor when pressed?
I feel something will get damaged if someone else drives the car and does not know about this and tries to press it hard to the floor.
Thanks
Posted on: 2004/4/15 12:35
1977 Datsun 1200GX
Subject Poster Date
     Clutch has been installed.What is correct play on clutch cable? 1200GXman 2004/4/15 12:35
       Re: Clutch has been installed.What is correct play on clutch cable? 1200rallycar 2004/4/15 14:20
       Re: Clutch has been installed.What is correct play on clutch cable? 1200GXman 2004/4/16 11:54
         Re: Clutch has been installed.What is correct play on clutch cable? A14force 2004/4/17 23:51
