Wanted kmh dash/cluster suit datsun 1200 ute dash
need a kmh dash cluster asap
prefer local but will pay postage if the price is right
pm me if you have it
thank you
Posted on: 2008/4/3 9:32
Re: Wanted kmh dash/cluster suit datsun 1200 ute dash
From Geelong, Vic
round or square dash?
Posted on: 2008/4/3 10:13
what exactly do you mean
i think its square its a early 70model mph 1 but i want a kmh 1 i just need the instrumental part not a whole dash
Posted on: 2008/4/3 11:05
Up to about 1975 or so the ute used the rectangular instrument panel that was used in most 1200 passenger models.
After that they adopted the three round instruments of the 1200 coupe & this is the most commonly seen ute instrument panel.
The rectangular panel/ speedo was mph in Aussie models, so unless someone has a privately imported kph one to sell, you would need to import one from a country that had them with metric markings or get an instrument repairer to convert & re-mark yours.
Posted on: 2008/4/3 11:14
Love your Datsun.
Treat it well.
will the round type fit in mine if it is a rectangle type orginaly???
Posted on: 2008/4/3 11:18
From Adelaide, Australia
You need the whole instrument panel but will fit your dash pad and you need to change the pins around in your dash connection, dattodude has a diagram in his album for the wiring, I did this for the racecars wiring and it works perfectly.
Posted on: 2008/4/3 11:26
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
so the round type will fit but wirring is different???
sounds like a big job do i use my plug and change the pins around or do i need the other plug aswell
whatever i find 1st ill do cause i want the mph gone and a km guage in
Posted on: 2008/4/3 11:32
From Canberra
There was a sticker you could get to change to km/h, I think it was available from auto stores. I'm not sure if you could still get one though.
Yep just change the pins in the plug, heaps better looking gauges from coupe/late ute!
Posted on: 2008/4/3 11:36
Just swap the pins around in your plug, easy job.
IPRA Build
From Mandurah, Western Australia
Made up some stickers for the coupe style speedo, So it reads kph and mph if you get stuck.
Posted on: 2008/4/3 15:11
