120y struts replacement?
From Wallan, Vic, Aus
HI there, wanted to know from any man or his dog if 200B struts and rotors will fit into a 120y, and are they shorter that stanza struts??
Thanks, and just remember that a peanut butter sandwitch does'nt taste nice with hair in it.
Posted on: 2006/3/3 9:37
Re: 120y struts replacement?
From sydney australia
not without replacing the lower control arms,
ball joints & steering arms,which can come from either a sunny or a stanza.the 200b struts are shorter than the stanza struts,but the bottom spring perch is larger.
Posted on: 2006/3/4 0:19
ah okay, why is it nessicary to change all the contol arms etc. also I went to the wreckers and mesaured a 120y strut, it is the same length as the 200b one. So it is of no use to me, as I'm trying to lower the car. I did have shorter springs on the stanza struts but it bottoms out on the smallest of bumps, so I put a standard 120y sping in which is about 1inch shorter than the stanza spring, but it is way to high. I don't want to pay $500 to have the struts shortened, there must be some way to lower it. Any suggestions? Thanks
Posted on: 2006/3/5 12:01
From Ipswich
Hey there
im shorting the 120y struts. Theres a bit of work involed. When i shorten them i fit coilovers so that you can adjust the ride. pm me if your interested or call 0421316757
Trent
Posted on: 2006/3/8 8:25
From sacramento california
is there a company that makes coil overs or adjustable coilovers for a 78 b210(aka 120y)?
Posted on: 2006/3/8 10:09
From Burbank, CA
there are conversions for 280zx turbo struts. It's a major investment since you get practically a whole new front end it's lots of work, but you're in luck because the guy I get stuff made by is in oregon.
the conversion is probably close to $2000 after you've gotten new brakes, adjustable struts, the coil, labor on modifying and rethreading the 280zx strut housing, stainless brake lines, camber plates,etc...
then you need to have it all installed and set up. fun!!!
Posted on: 2006/3/8 18:08
|||\ 81 KPB310 /|||
From Las Vegas USA
I bought the entire 280ZX set-up with modded cross memeber , struts , camber plates , calipers milled to fit in a 13" wheel , radious rods , steering box and drag links for $1100 used in 1992 so I would say $2000 sounds about right. I used the scales we had for our local SCCA races to set up the car.
Tom
Posted on: 2006/3/8 21:35
From Burbank, CA
am i going to need to mod the x-member? I haven't heard anything about that. or is that for other things like adjustable swaybars?
Posted on: 2006/3/8 21:43
|||\ 81 KPB310 /|||
