a 12 horse power
From SOUTH COAST
it has probably been asked before but.can anyone tell me the best way to get good horse power out of an a 12 engine.the only thing is it has to retain the same carby.do they have a flat top piston avalible and an oval port head.it has to be an a12 otherwise i would have gone for an a14 or 15.can i get same pointers.are there any sites i can read up on or tech sections. thanks you
Posted on: 2009/2/24 8:51
Re: a 12 horse power
From Townsville, Qld
You suffering form P plater? The thing is that the standard carbies are really only an economy carbie, you can't get more out of them unless you have all the gear the Japs are using in their historic class racing.
But for fun that doesn't look illegal I'd go a weber 32\36 carby conversion, I mean weber make all this stuff for "problemmatic" carbies. I reakon that standard carby is "cough" "problematic"
Add a slightly larger exhaust all the way through and it'll be fun
Posted on: 2009/2/24 9:17
From Darwin NT
just get a gx setup
Posted on: 2009/2/24 9:19
current project 4x4 patrol...
From Melbourne vic
Did you see how much Chris's went for?
Faaark me
Posted on: 2009/2/24 9:20
:Impressive, will it fly?
:Yes, if i fold it here and here
:Nice
From Darwin NT
and his a15 motor
Posted on: 2009/2/24 9:29
From Melbourne vic
I know he was offering it here for $350 or
something, that is mad! I should sell my a12t
getup once it's all shiney!
Posted on: 2009/2/24 9:32
:Nice
From Las Vegas USA
There are several things you can do: First off you can rejet the standard carb. (Weber 32/36 would be better of course) As mentioned you can go to a bigger exhaust. The flat top pistons will help regardless of any other mods. On the oval port head if you have the carb that came with it use that. You can also gasket match the manifold/head. Electronic ignition from a 120Y.Go to a 14lb flywheel. Keep it in proper tune etc. I would guess you that you could get the A12 up to the 75-78HP range. You might be able to ditch some weight out of the car as well.
Tom
Posted on: 2009/2/25 1:44
From adelaide hills
ive heard a fair bit bout flat top pistons.
how much are they worth and are they easy to come across
Posted on: 2009/2/26 10:06
1977 1200 ute aka franky weekender
1979 sunny wagon aka rod the second daily
From Brisvegas, oz
turbo injection and electronic ignition...boom thats 100 horses right there... or 100 shot of nos. lol
Posted on: 2009/2/26 10:24
www.camerasplus.com.au
From Adelaide, Australia
A10 Pistons are flatop as far as I know.
Posted on: 2009/2/26 11:15
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
