car wants to stall
just instaled a l20b adjusted the timing,new spark plugs the works.but im having a problem with it wanting to stall when i go to take off or when i hit the pedal to quick.please someone help.
Posted on: 2003/8/15 3:24
Re: car wants to stall
From Sydney, Australia
Carburetor Accelerator pump jets are either too large, or blocked. This is almost certain if it happens when you take off, but is fine at idle, and at speed.
Trust me
Chris.
Posted on: 2003/8/15 5:33
From Canberra, Australia
Hmmmmm..... Tried the old : Reving the crap out of it and covering the carb with your hand to suck any crap out of the carby trick?
Posted on: 2003/8/15 15:01
1971 Datsun 1200 Coupe
A15 Engine. Holley G180 (32/36 Weber). extractors and 2 inch exhaust.
Standard 1200 4 speed with lightened fly wheel and HD clutch
Stanza front struts and brakes.
15x6 CSA Wheels with 195/50 rubber.
the hand on the carb worked.it doesnt want to stall now when i hit the pedal.now if i put in park or nutrual it goes to a high idle.if i set the idle down it wants to quit or it stalls when i put it in gear.it is driving me nuts.
Posted on: 2003/8/16 3:52
Good call, Lobster.
5&Dime, sounds like you have a vacuum leak somewhere, maybe a hose end, hose not connected, broken vacuum diaphragm or leaking intake gasket.
Posted on: 2003/8/16 4:52
airleak is the problem but from were i dont know.any ways to check for a leak.
Posted on: 2003/8/17 22:09
From Brisbane
yeah i had same problem with my hitachi, turned out there was a hairline crack init somewhere and it was rooted someone had droped it before i got it, easy answer for me was get the 32/36 no problems after that
Posted on: 2003/8/18 0:39
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
There are some tips on checking air leaks in the Tech Section article Carb adjustment, troubleshooting, rebuild and inspection
Check the play on the throttle shaft ... spray the carb-manifold junction ... two ways to check for vacuum leaks in the vacuum motors ...
Posted on: 2003/8/18 0:58
