« 1 2 3 (4)
Re: 9 inch diff
From sutho shire
how about a hilux diff if so how hard are they to engineer and do they cost alot thanks all so i will be running a ca in the datto
hilux's are second 2 a 9'' in strength.. nearly same axels as a 9'' fitting isnt that hard cut down and new brackets made and fited with 4 stud is about 1300$.. ive decided 2 go for a mini spool set up on my hilux diff.. as same as mate bella.. Lsd's are alvailable but are hard 2 get hands on.. as for tramp kits.. DONT BOTHER they sit 2 low to the ground and look like SHlT u are better of getting your leaves reset lower like i have (flat) and leaving the bottom plate in.. only 2 diffs i would look at for 1200 ute ca18det conversion is hilux and R31
Posted on: 2003/12/16 10:00
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: 9 inch diff
does ne body no where i can get hilux diff from e.g website this would be very help full thanks
Posted on: 2003/12/16 15:01
Re: 9 inch diff
From Collingwood. Victoria. Aus.
Hey DVLDAT
It must be time for a change for you or me.
I am starting to get a headache from your avitar
Posted on: 2003/12/16 22:32
Never ever grow up
Re: 9 inch diff
From Melbourne, Australia
hey 2332, my bro would be very interested in talking to you as he has the 33 or 35" inch tyres and 5.3 diff ratio too, ill post a pic of his beast soon, but he was saying he could only use the lock rite with a certain type of hub (cant remember what its called) but you have to engage it by hand for 4wd, im sure you know what i mean, his concern with that is that his car has some real flash wheels with centre caps and he wont be able to use these if he converts his hubs
anyway he will have a more accurate question for you but that is his dilema, expect an email from him ok
cheers mate
Posted on: 2003/12/17 1:25
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
« 1 2 3 (4)
